9
98 SVT Offline OP
9
I hear all this talk about the fuel pills with the ZEX kit. Are these supposed to come with the kit?? All I have are the HP pills of 55,65,68,75.. Any help would be appreciated. Also do I need the balk head fitting??
00 Audi S4
Silver and Black
(Bone stock)
98 Toreador Red SVT
#742/6535 (Totalled)
KKM induction,Sho-Shop Y pipe, removed resonator, Superchip,
B&M Short Shifter, Fog Light Fix
885 Fogs, Xenon Super Whites
Clear Corners w/clear bulbs
Removed Door Dings, TH Fix, ADR Phase II white 17s and Kumho rubber
What size jets (pills) did you get? Read the number on them. You should have gotten 5 pills. They should be .032, .034, .035, .036, .038.
Now, this is gonna sound really crappy, but don't take it to heart. I mean it in a good way. If you bought the kit brand new, sit down with the directions and read them front to back, because it is quite obvious you haven't researched this enough. You can end up with bad issues if you don't sit down and understand what you are doing / about to do. First, go to Zex.com and read all the stuff you can on there. It would explain the difference in all the pills. It will also answer most of the FAQ's. If you still have issues, ask someone who is familiar BEFORE you start messing with the install. I have a bit of experience with the ZEX kit, but othere people on here have more with other N20 applications.
1991 GVR4
Lots of mods done.
9
98 SVT Offline OP
9
See I only have four. 32,35,36,and 38. The nember show that they are all HP pills except 36 which shows its a 55 fuel pill. Is this correct?? Also I bought the kit used..
00 Audi S4
Silver and Black
(Bone stock)
98 Toreador Red SVT
---------------55hp-----65hp-----75hp
Nitrous Jet----- 32------ 35-------38
Fuel Jet--------36------ 34------ 32
Ignition Retard-- 0°-------2°------ 4°
As you can see, the N20 jets also double as fuel pills in some cases. Go to the website I linked in my first post and that has a the install directions as well as an FAQ and stuff. That chart is 100% correct.
1991 GVR4
Lots of mods done.
