Posts: 1,244 |
You shouldnt void anything on your warranty, especially if you can take it out.
sorry Dom I didnt see JCBoeckl's post. Thanks anyways.
Posts: 463 |
Last I've heard, the Sho-Shop ones have been re-designed with floating mounting points to address the broken struts issue.
Posts: 1,592 |
Originally posted by SVTimulate: Last I've heard, the Sho-Shop ones have been re-designed with floating mounting points to address the broken struts issue. Still garbage IMO, Nothing should mount to the struts period!
Posts: 2,481 |
Originally posted by Ghosst: Here's mine, in Ford Engine Blue.
I noticed a big improvement in turn-in with mine. Definitely worth the money for me.Off subject, I didnt know Cosworth make Duratech engines.
99 Range Rover 4.6 HSE Mystery Car??????
Posts: 316 |
Originally posted by Icey Mike: Off subject, I didnt know Cosworth make Duratech engines. They don't make the duratech, they designed it.
Posts: 424 |
Here's my front strut brace-it's a Weichers Sport aluminum model from Tuning Zubehor(imported from Germany). Also noticed better turn in, and tightened up the rear with a matching bar.
2000 SVT silver/blue #1699 of 2150 14.793@94.88 Sho-Shop off road y-pipe for sale($75)
Posts: 348 |
how do you install the weichers one?
Da Stealth Moblile
Posts: 3,237 |
Originally posted by wavrdr: Here's my front strut brace-it's a Weichers Sport aluminum model from Tuning Zubehor(imported from Germany). Also noticed better turn in, and tightened up the rear with a matching bar. :cool How much?
Posts: 1,444 |
yes do tell. how much. where can one find that catalog/website.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 424 |
Ok guys, the Weichers Sport bars came with nuts and bolts for a reinforced installation, I believe it's becuase these are the bars used on some of the BTCC cars, so they were built for high stress. The front bar is a "twin tube" design, no adjustability, and sells for $234(aluminum), and $139(steel,I think). I was very happy when the bar arrived to see that it was twin tube, and had a nice reinforcement plate connecting the 2 tubes with 2000 Mondeo stamped on it. The rear bar is just a straight bar with a wing on each end to attach to the rear towers. Drilling and bolts are needed for the rear also, and the price is $139(aluminum) and $99(steel). I found the bars in the catalog that they sent me, called them up and ordered them, front was in stock, but the rear was out of stock and had to be imported from Germany, needless to say it took a couple of weeks.
