Posts: 104 |
i just bought a mini blue neon that i am mounting uder my deck near my shifter and i want it to turn on with my headlights... the problem is i dont know how to power it i tried splicing into my door lights but it didnt work.. was it not enough power?? any help would be appreciated.
95 gl I4, naxor R exaust, k&n intake, taylor wires,wings west touring wing, 98 se sideskirts, custom back bumper,catz fogz,2 15" jensen XS subs with mean machine amp
Posts: 112 |
try relaying of the headlight switch
Posts: 104 |
and how would i go about doing that im not too good with relays n such.
Posts: 213 |
if u wanna do the simply way...juss run the wire to the fuse box where the headlight fuse is
Posts: 104 |
my neon has a green wire and a red one... is it possible to run it through the fuse box under the drivers side dash or do i have to use the one under the hood...and if i can use the one under the dash do which wire do i needd to connect and where do i ground the other one if neeeded
Posts: 145 |
trick...neon has a main power and a ground...you must run the black wire (green) to a ground..and run your power (red) threw a switch...if your not sure about wiring a swtich...all you do is buy a simple 2 way switch in the case you run your power ( red wire) to the switch and run another wire from either your fuse box which has either a constant power or one that turns on with ignition...its so you can turn it on and off when ever you want...do you really want it on all the time??? sorry i didnt tell ya where to ground...a ground you will just need to take a ring terminal...like $.5 cens at your local hardware store and drill a hole and put a screw threw that ring terminal so you have a solid ground connection....
Posts: 104 |
ok lemme see if i got this straight... i ran my red wire to my instrument cluster illumination fuse under my steering wheel all i have to do is ground it... any ideas on a good place to ground????
Posts: 213 |
if u can't find an ez ground u can always ground it to the ground terminal on your battery otherwise just find a bolt that is in the floor and put it under there
Posts: 97 |
Another option to have it go on with the headlights is to hook it up to the extra wire you would would have taped off if you did the fog light mod.
'99 SVT, Black,Tinted 30% in front,limo in the back 3, Pioneer 8400MP, Pioneer 3-way 6x8's, clear front corners and a custom SVT banner. It's ready to smoke the competition! #291 of 2760, Shsflyguy@yahoo.com
Posts: 908 |
I have red neon under my driver side footwell and the passenger. With the use of 2 relays mine go on whenever the dome lights go on and go off when the dome lights go off, also i have a switch were it can stay on all the time, wether the car is on or not.
Mike | 98 Silver CSVT
