Page 2 of 2 1 2
F
FSU SVT Offline OP
F
I'm glad you said you are happy with the quaife because I had bought one when the price went down. But as for the clutch and flywheel I'm going to go with the unorthodox racing clutch and lightened flywheel. If anyone has these driveline upgrades, please let me know how you like it.
That exactly what I have...Quaife,UR Clutch Stage 1 and Shoshop Flywheel...I don't know who else has this setup but I like it besdies the added clutch noise.
Louis
2000 Silver Frost SVT ... #718 of 2150 ... Built on 12/3/99
Click here to see all my mods... My SVT
Forget UR, Clutchmasters is a much better unit. Ur makes a great pulley, but thats as far as I would go.
Oh and FSU, really foolish to be going banging around on your clutch so early, you should break it in for at least 500 miles, stop and go normal driving, anything more and you take a big risk of causing premature wear to the disc surface, in turn, early failure, and not a 100% working clutch...Naughty, Naughty..... confused
Performance Xpress Racing
Silverbulitt@msn.com
Our websit www.PXRacing.com is coming soon!!
We carry Contour/Cougar parts for the 2.5 Duratech and 2.0 Zetec
F
FSU SVT Offline OP
F
Yeah I know what I did this weekend wasn't the best thing for my clutch...but only twice did i leave it in second gear and accelerate quickly out of the corner one on a left hander and the ther on a right hander just to see how the Quaife was working smile ... other than that I have babied it around town the rest of the time...up to about 300 miles now...can't wait till I put on about 700 miles on it then I will gradually start to give it more abuse, then after that comes some SCCA at the local airport, once I get a 24mm sway bar smile
Louis
N
N
Let me know if it starts slipping on you. You might also want to keep your ears open for any moaning...especially after some time and during cold weather.
98 Black E0 #946 of 6535
Koni struts & Eibach springs
24mm Aussiebar
Pro Flow 75mm MAFS calibrated to KKM filter
Wilwood Brake Kit with cross-drilled rotors
Clutchmaster's Stage 1 Clutch & Fidanza Flywheel
Custom Dual Exhaust with an Xpipe
MSDS Headers
Custom Cold Air Intake with KKM filter
Dyno'd at 177 hp and 156 ft-lbs
F
FSU SVT Offline OP
F
What do you mean by moaning ?
Page 2 of 2 1 2
