Well the weather finally cleared up and I was able to take some pictures of my latest mods.
FYI: I washed my car yesterday and put a quick coat of Z-6. Then later that night it rained.
Went out to my car this mourning and found it looking almost as good as after I washed it. So I figured I'd take some pics, and thats what you see.
The front/rear lower grills were somewhat hard to get attached. The rear I used rivets and large washers to hold it in place. The front we did last and were able to use the existing clips to hold it in place. After several coats of paint on the ring, and alot of cuts from the VERY SHARP alumn. Mesh
This is the result.
Thanks to Elky for the Mesh. I liked it because it had large enough holes to not restrict air flow and was durable enough to withstand light impact. Although, due to the large hole design, it was hard to cut the mesh correctly. So it wouldn't show any holes. Overall I am very happy, it gives my front end a very aggressive look!
Below are pictures of my engine which hasn't been cleaned in quite a while so please excuse the dirtiness!
I changed the hoses to Ford Blue and added FMS 9mm Wires. I might be painting the OMP bar Blue as well, but I'm not sure if it will be too much Blue? What do you guys think?
Oh yea...I also added the Bonnet Lifters, which I love! Thanks to the Group buy for the great deal!
