Page 1 of 3 1 2 3
#356541 12/31/01 10:35 PM
BP Offline OP
Decided to use my day off today to spruce up the exterior.
Added some cheapo side markers from Pep Boys and a short chrome tail pipe barely visible in first pic.
-Brian-
98 SE DTec MTX
#356542 12/31/01 11:20 PM
Very, very, nice! One of the best se's i have seen! those are the kind of rims i want, 17' cellos? what did you pay for them and the tires? wink
1999 contour se sport- black mtx
-Duratec v6
-dual exhaust
-no resonator
-kkm induction system
-one loud stereo
-35% window tint
-18' Enkei CDR9's on Kumho Ecsta Supras.
-Audi A6 Sidemarkers
(Coming Soon, Very Soon.)
-SVT front and rear bumper.
2002 Passat V6 GLX 4Motion
#356543 12/31/01 11:28 PM
BP Offline OP
Thanks! Now all I have left on my exterior mod list is mesh grill and bat suspension kit. The 17" cellos with tires (Dunlop SP 9000) mounted from tirerack.com were about $1100...I think. That was a while ago.
-Brian-
98 SE DTec MTX
#356544 12/31/01 11:54 PM
I really like the rims. laugh How much did u pay?
#356545 12/31/01 11:55 PM
Try to get a good pic of the tail pipe. I'm curious to what it looks like, but over looks pretty sweet.
#356546 01/01/02 12:09 AM
9
9
So that's what side skirts look like with regular SE bumpers. Great... you convinced me to get some!
Love the side marker mod. How did you do it? How expensive?
Matthew
98 Contour SE V6
Matthew
98.5 Contour SE V6
It has spent 1.5 years under the wrong identity ;-)
#356547 01/01/02 12:59 AM
BTW, those are not the SVT skirts (if that is what you are thinking they are). They are the SE skirts....
1991 GVR4
Lots of mods done.
#356548 01/01/02 02:13 AM
BP Offline OP
Matthew
98 Contour SE V6
Yes those are the SE side skirts just in case you couldn't tell.
The side marker mod was very easy except for widening the hole in the fender. Took about 4 hrs total including strengthening the fixtures with 3M bonding glue before putting them on the car.
The existing hole was not large enough and required some widening. I used a pair of pliers to bend out the existing holes, then used a coat hanger to run wires from inside the engine bay from the hole by the hood latch to the fender hole. Next I removed the headlight fixture to get at the parking light fixture, then spliced the ground wire from the light fixture to the parking lamp black wire (ground) and power wire from the light fixture to the parking lamp blue wire with the orange stripe. Its only setup to work with the blinkers. I'm considering adding the parts to have it work with the parking lamps and blinkers but want to leave it as is for now. There is a pretty extensive write up in the Mods section that I referred to while putting mine in, helped a lot.
$16 for both fixtures which included everything. I bought an additional set of white bulbs cause I didn't like the amber ones that came with the package.
-Brian-
98 SE DTec MTX
#356549 01/01/02 04:05 AM
drop that bad boy about an inch or two and you'll have a real looker
#356550 01/01/02 07:14 AM
yea it needs to be droped a little
Michigan CEG BenTonEdge@aol.com
**DEAD** Dec26 01. 96 2.5 Gl dessert violet. mystery mod, gutted cat. no res. craked secondaries. custom air box. And a good old CEL Oh you want to know
Page 1 of 3 1 2 3
