My goal here is to build up a turbocharged 3L to it?s best possible output? and have the transmission/differential survive under the new ?circumstances.? Again, lemme know where I?ve gone wrong and where I haven?t? please?
So how?s this...
Purchase 1 - $300-$?
- ?Open-element? filter w/ heat shield, $40-120~
- Pro-M 75-80mm air intake monitor (70mm was a typo :p), $220~
- 62-65mm throttle body (best way to buy??)
Purchase 2 - $900-$1300
- MSDS headers $500-$600
- Custom 2.5? dual exhaust; one 2-in/2-out high flow cat, one 2-in/2-out resonator, two 1-in/1-out mufflers, $400-$700
Purchase 3 - $420-$?
- Energy Suspension motor mount inserts (MTX only?), $20~
- 22mm front/rear sway bars and bushings, $220~
- SHO Shop strut bars, front and rear, $180~
- Subframe connectors (when available)
Purchase 4 - $370-$470
- Jacobs ($300) or MSD ignition ($400)
- FMS 9mm spark plug wires, $50
- High vacuum pressure hose kit, $20
Purchase 5 - $800-$?
- '01 3L block prep and swap, $800-2200
- Titanium (hollow?) pistons and connecting rods, $?
- New piston rings, $?
Purchase 6 - $400-$Sky-high
- 6-speed a-od tranny or rebuild CD4E to spec, $?
- High performance torque converter, $?
- Phantom Grip limited-slip differential, $400~
- New cams, camshafts (when available)
- New cam gears, seals (when available)
Purchase 7 - $3000-5000~
- Hightower?s Mystery Co. Turbocharger
Purchase 8 - $1360-1860 (whew!)
- 17x7-8 wheels, $500-800~
- Nitto tires, $400-600~
- Eibach Pro-Kit springs, $290~
- Koni adjustable shocks/struts, $170~
Purchase 9 - $995~
- Larger (slotted) rotors, calipers, pads, $900~
- Stainless steel braided brake hoses, $95~
Parts I?m Still Unsure Of - $?
Better dual electric cooling fans
Better fuel pump
Better oil cooler
- High-flow oil pump
- Baffled oil pan (haven?t had a problem yet, but..)
- Larger radiator (larger than SVT, already have two of those :))
- New fuel filter (need one anyway :))
- 22-24pph fuel injectors
- Fuel injector rail
- Fuel cooler
Thanks for humouring a newbie...
.RMk..
