Page 2 of 2 1 2
What are the stock SVT injectors rated at? I assumed they were 19 lbs....
dion
98 SVT with some mods
http://communities.msn.com/contourstuff
9
9
Originally posted by ScottK:
You are right - but almost new 19# mustang injectors are easier and cheaper to find.
The new mustang injectors are 24lb, maybe the v6 ones are 19lb?
That's quite an outline that you got goin' up there! It's very helpful though, thanks!
97' 2.5L Contour SE -T-Red
Midas exhaust (grr...), Sony CD player, K&N airfilter, Mobil One Synthetic Oil, removed intake resonator, modified MAF, in-fender CAI, painted grill, Platinum tipped NGK's.
I am looking for SVT E0's or E1's, SVT Upper & Lower Intake, SVT Throttle Body, and SVT Exhaust. If you are selling, e-mail me!
Ford4eva@hotmail.com
Does anyone know what size this injector is?
XW43-9F593-CA
I know it is for a ford V8. I couldn't find it anywhere on the web. But I haven't called a dealer yet.
Green 2000 SVT #1166
mods-K&N open air filter & Custom heat shield, Custom y pipe and 30 in resonator,DMD, arm rest heightened
http://www.geocities.com/savinoss/Cars.html
other cars-89 sable 197000 miles and still going-Wifes car 99 Mystique V6 5 spd
9
9
Good luck with the installation! Post all of the details after you've finished.
1
1
I'll try and get some pics - the swap should be pretty straightforward now.
I guess the big question for the early guys (97 and before) is do we really need the new lower. I have two extra injectors, so I'll see how they fit in my original lower.
FWIW, I know that you can NOT use a new lower manifold with an old side feed fuel rail - the side feeds require one bolt per injector to hold the retaining clips, and they don't have enough holes on the new lowers (only has 4 bolts holding it).
Page 2 of 2 1 2
