Posts: 134 |
I need to change my trans filter my car now has 80,000km on it i was wondering what trans fluid to use.Thanks  [img]null[/img]
1998 SE atx Svt exhaust No rez Svt rims Cta intake B.A.T handling kit Door dings all gone Sony 850x head unit,10 disc cd changer,2 12 JL Marathon amp 600w Painted brakes red :o( dyno at 123hp/133tq(stock) Mods in the mail
Master P
Master P
Posts: 5,455 |
Mobil 1 or Redline.
The filter is not serviceable.
Posts: 134 |
[QUOTE]Originally posted by reaper4tour: [QB]
well thanks for telling me that all i do then i guess it is like a oil change just a little more money.
Posts: 2,683 |
AMSOIL!
Howard 1998 Silverfrost SVT #1612 June mods: 17" ADR RS Limited Limix Wheels with 215/45/17 Yokohama AVS Sports
Master P
Master P
Posts: 5,455 |
Originally posted by reaper4tour: [QUOTE]Originally posted by reaper4tour: [QB]
well thanks for telling me that all i do then i guess it is like a oil change just a little more money. Check out this message: http://www.coldair.org/archives/9909/msg01152.html
Posts: 3,950 |
Hey Perry, what do you mean the filter is not seviceable? You can't change the filter when changing the trans fluid?
Posts: 3,584 |
I'd go with Mobil 1. I have Mobil 1 ATF in the gearbox of CSVT, it took 2 quarts and cost me a total of about $20.00 total parts and labor. Also just an FYI, the trans is supposed to be "seviced" every 30,000 miles. Preventive maintence is alot cheaper than a new transmission
Roger R SVT/SHO Society SE MI rep 2000 CSVT #1253 of 2150 silver frost/midnight blue 2-8" dark blue racing stripes Mequiars...simply the best! "...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4" USMondeo@aol.com
Master P
Master P
Posts: 5,455 |
Originally posted by LoCoZetecSE: Hey Perry, what do you mean the filter is not seviceable? You can't change the filter when changing the trans fluid? Right. Only normal service to the tranny is changing the fluid.
Posts: 59 |
91 Honda CRX Bilstein shocks, Tenzo R springs 96 Ford Contour LX V6 ATX KKM intake, Ford Motorsport 9mm wires All Kenwod Stereo System - 134db KDC-8016 headunit, KAC-859 amp, KSC-BP210 bandpass, DualMags: 6.5" front and 5.5" rear
Posts: 2,657 |
I run Mobil 1. Its a little cheaper than AMSOIL and Redline.
