Posts: 32 |
FYI, the new Mondeo has 5x108... Std equipped with 205/50x16...
'97 mkII 1.8 sedan, mtx, Diamond White, Magnecor KV85, clear side repeaters
Posts: 3,223 |
Are we forgetting that you would have to have the drive shafts re drilled as well. The studs are actually mounted to them not the rotors.
-Andy
Posts: 569 |
Originally posted by Andy W.: Are we forgetting that you would have to have the drive shafts re drilled as well. The studs are actually mounted to them not the rotors.
-Andy Thats what I was wondering this isn't goning to be just a brake swap first your gonna have to change your cv joints and axles if a contour has rear axles haven't looked. After you spend all the money for the conversion you won't be able to afford rims.
**Spelling should not count**
2000 SE Zetec ATX Medium Steel Blue (Now with large custom dent on the rear door) Cool Blue Lows, Silver Star Highs (great lights)
"If what I said was wrong, it wasn't. I just forgot to add the rest of my post."
Posts: 5,805 |
No,the drive shaft goes through the hub flange that carries the lug studs,its a m/c flange you need & a new hub flange on the rear$$
Posts: 724 |
Blah, just look at Team Dynamic's rims they custom drill all of them
98 V6 Lots-o-mods SOLD 88 Daytona Shelby Z TII (The beast) 87 Daytona Shelby Z TII (Holy 20 psi of boost batman!) Mods- 3" Downpipe, Hi-Flow cat, 3" mandrel bent exhaust with Dynomax Ultra flow. Manual boost controller, TurboXS blowoff, 5th injector, large canister wastegate, Nitrous Express go-fast-be-happy kit, ported exhaust manifold, ported intake manifold, upgraded motormounts, eibach springs, strut tower brace. Oh and 20 PSI to boot.. my oh my...
Posts: 1,687 |
I just got 18" Konig Verdicts and they only came in the 4x100 in the 18" so I have to get mine custom drilled. The ADR Reaction is the same wheel basically and it comes in the 4x108 pattern. If I would'nt have gotten such a good price on the Konig's, I would have just gotten the ADR's to save the hassle and voiding the warranty.
Posts: 1,090 |
Originally posted by Terry Haines: No,the drive shaft goes through the hub flange that carries the lug studs,its a m/c flange you need & a new hub flange on the rear$$ Okay, you'd need to get the hubs and rotors re-drilled and new studs pressed in, but I have another question, how about using the new Escape's hubs? Is that a possibility? I was also thinking of getting my hubs and rotors re-drilled, but a buddy just told me to save my money and get HRE wheels instead....LOL.
Posts: 5,805 |
I think redrill on the hubs is the wrong term,remade or changed is better,unless you plan on having the existing holes 'welded up' and redrilled!  (no,dont go there!).Using another hub/bearing/knuckle/driveshaft combination would prove a major pain!.I'd only have the wheels 'redrilled' if the supplier can change the position of the holes BEFORE the first ones are drilled,not all wheels are cast to have 'meat' in all the right places,redrilling existing 'holes' will give you 'egg shaped' holes.
