Posts: 4,899 |
What the fork is that?!
Posts: 3,636 |
I gotta agree with Chris. Look where the photos came from. This guy is either a few fries short of a happy meal, or he gets of on getting other people going down the wrong track. Check out Phil TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Posts: 4,042 |
 I didn't really check the sourse where it was coming from, just saw it on another 'stang board. I've been assured that it's not what the '04 stang will look like, nothing remotely close. My heart is beating again.  John
Posts: 288 |
looks like a z-24 from the rear (if you look really quick) but a cougar from the front. the rims look too much like the cougars now too. i would agree, if this will be the "new" mustang, forget about the car now. the 6-cylinder is bad enough...but this...
former proud owner: '98 silver frost svt #4109 of 6535 build date: 11.13.97 purchase date: 11.13.00 sell date: 12.8.01 15.717 @ 90.95 mph (first run ever) bridgestone potenza's s-03 pole position* silver painted calipers * black pin stripe * "saleen" location build number in metalic gray * otherwise completely stock
"that was commercial material...i was waiting to see words pop up at the bottom of the screen."
Administrator
Administrator
Posts: 4,527 |
I doubt there would ever be a mustang that was that ugly.
It's all about balance.
bcphillips@peoplepc.com
Posts: 178 |
I've seen the new Mustang and that is not it. Be patient...you won't be disappointed.
98 Black E0 #946 of 6535 Koni struts & Eibach springs 24mm Aussiebar Pro Flow 75mm MAFS calibrated to KKM filter Wilwood Brake Kit with cross-drilled rotors Clutchmaster's Stage 1 Clutch & Fidanza Flywheel Custom Dual Exhaust with an Xpipe MSDS Headers Custom Cold Air Intake with KKM filter Dyno'd at 177 hp and 156 ft-lbs
Posts: 148 |
Looks pretty similar to what Motor Trend wrote about. http://www.thehollywoodextra.com/Ford/ford.html
98 SVT Black w/ Midnight Blue Stock Rims Sparco Pedals Removed Resonator TH Fix Superwhite Bulbs B&M Shifter K&N Filter KVR Cross-drilled rotors (front) KVR Pads (front/back) Aeroquip Steel brake lines (front) #4248 of 6535 built 15.574 @ 88.35mph 15.814 @ 86.62mph
Posts: 148 |
Posts: 3,419 |
Whoa! Page 2 of the Motor Trend says that a 3.0 Duratech might be the base V6 on the D/EW Mustang! IRS and DOHC high rev power! (Ford will probably choose the SOHC 4.0 instead just to spite me.) And then there is the plans for a blown 4.6? And a paddle shifter on the Cobra? And a six speed as the base MTX! If half of the things in this article are accurate, I don't think I'll care how ugly they are. I wonder what it would take to get the wife to wait until 2003/2004 for her next car? And to convince her that buying a Ford is a good idea after the Contour fiasco. Somebody needs to shoot Rara full of sodium pentathol and find out how much of this is accurate.
Posts: 22 |
I would like to echo what NYKnicksSVT said. I too have seen the '04 stang and that is nothing close. It will look way better.
Silver 1999 SVT #1938 of 2760
