Page 3 of 4 1 2 3 4
Originally posted by matthewbounds:
My only problem now is that on cold startups my gauge idles at 75 and goes past the 100 with some gas. Once it warms up everything goes to normal. Any suggestions?
My 93 SHO will cold idle at 70 psi but would hot idle at less than 10psi! (10W-40 Mobil 1)I was told this was the reason they never included a oil pressure gauge in the SHO. Drivers would freak out. This was normal. The system was a low pressure, high volume design.
Paul Dippel
93 SHO MTX
99 SVT Contour
68 Mustang Convertible
http://www.fortunecity.com/silverstone/alfa/971/
V
V
randyj - Thanks for the info. smile
Its a waste of HP to run excessive high oil pressure.The rule of thumb is 10 psi per 100Hp for hot oil!
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
So which guages are better/more correct?
Mechanical vs. Electric
Silver 98 SVT Contour E0
#4124 (Currently on Life Support)
Built 11/97 Bought 1/98
Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods
Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI
"Come Out...Come Out Where Ever You Are"
http://www.geocities.com/speeddemons19
Mechanical oil press,electric oil/water temp.
V6 MTX
Fuel pressure?
'In -car' electric,under hood mech(unless you have a pressure breaker for the mech),then it can be mounted 'in car'.
V6 MTX
I know MOE66 had posted some pics but I was wondering if anyone any real "how-to's" for electric oil temp., oil press. and air/fuel ratio. I can't really tell from the pics that were posted where they are supposed to go. I have the gauge pod and these guages at home waiting to be installed....I'm just to chicken to do it until I get "real life" aka Contour, experienced howto. Probably asking for much but just wondering....
Thanks! smile
I
I
Thanks! smile
The gauges are very simple to hook up. Send me an e-mail at: mallmon_com@yahoo.com and I could guide you through it.
99 Range Rover 4.6 HSE
Mystery Car??????
You've got mail! and 5 stars!!! laugh
EDIT: Well, in my mind you have 5 stars...Can't give them to you though....Not available.
Page 3 of 4 1 2 3 4
