Posts: 1,041 |
I would tell you to go with Silver... I have red ones on my Silver SVT.
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
Posts: 1,664 |
I personally like siver...nice safe color to go with.
Joey 2000 SVT Black #1811 of 2150
Dad always thought laughter was the best medicine, which I guess is why several of us died of tuberculosis.
Posts: 1,038 |
what color for a green svt? i keep thinkin yellow, black or silver. but i dont want to do yellow. any opinions?
Posts: 304 |
Yellow definately! Mines green and yellow Contrasts nicely. Theme carried on into engine bay
Mad Mole Visit Mad Moles Mondeo Madness 2L Zetec, Cams, Stage 2 head, Valve work, Powerflow, Unichip, AEM Ram, K&N, Ecotek, 75mm Lower etc. 192 BHP, Faster than a speeding Duratec!
Posts: 1,664 |
Originally posted by Stinger00: what color for a green svt? i keep thinkin yellow, black or silver. but i dont want to do yellow. any opinions? You can see yellow for yourself...this is Blitz's SVT...
Posts: 275 |
And with the yellow, your braking distance will be cut in half!
:p :p :p :p
(I like the silver)
95GL25
Posts: 1,070 |
that looks good joey...is it really that easy? i think i would go with silver too.
what is the best paint to get?
Proud former owner of..... '99 svt - silver/blue - #2555 of 2760
Proud new owner of... '02 BMW 330i
Posts: 1,664 |
I got a high temp engine paint from a spray can, sprayed it into the lid (VERY FAR AWAY FROM THE CAR...DON'T WANT OVERSPRAY), then used a 1/2" brush to apply.
Lift car
Take the wheels off
Clean the brakes first with a break cleaner spray, use a wire brush if really bad.
Let dry
Brush on paint as stated above...some say its best to remove the caliper...but I didn't. Use a Q-Tip to get in the hard to reach places. Just be careful if you're not taking the brakes off.
Let dry before putting the wheels back on...couple hours at least.
Posts: 1,187 |
how the hell do you guys keep your wheels so clean? mine are like permanantly getting discolored in areas because i cant keep the brake dust off of them.......
-Speed Demon- Matt Black 2000 Contour SE Sport (duratec/atx)got body mods? all show, better than stock go  "I might be crazy, but I'm not stupid" speddmn.com
Posts: 2,847 |
My theory was, if you're going to do it, you might as well make it show. I was originally going to do silver, but just wasn't flashy enough. If I were to do it again, I would probably go a little darker, but I am happy with the results.
