Posts: 2,906 |
I raced a GT off the line at back to back lights and one by a car length each time. They are quick but can't hang with a mostly stock SVT and wouldn't even be worth racing against a Supercharged or 3 liter SVT. :rolleyes:
And dead, you might wanna work on that first impression thingy a little more. We get people doing that all the time on this sie and it gets a little old.
And get an SVT! they are still around on dealer lots. probably not new though.
Josh Aka Spectra SVT 02 Dark Highland Green F-150 XLT Mods: Gunrack and cowboy boots
Posts: 462 |
I CARTESTed (ver4.5)each and came out with:
1997 Ford Probe GTS 0-60: 7.8 sec 0-100: 20.2 sec 1/4 mile: 15.8 @ 88.6mph top speed: 133mph
1998 Ford Contour SVT E0 0-60: 7.5 sec 0-100: 19.5 sec 1/4 mile: 15.6 @ 90.3mph top speed: 138mph
2000 Ford Contour SVT E1 0-60: 7.3 sec 0-100: 19.0 sec 1/4 mile: 15.5 @ 91.1mph top speed: 139mph
1998 Ford Contour GL automatic 0-60: 9.5 sec 0-100: 31.2 sec 1/4 mile: 17.5 @ 79.0mph top speed: 116mph
1995 Ford Contour SE manual 0-60: 7.7 sec 0-100: 20.0 sec 1/4 mile: 15.7 @ 88.8mph top speed: 136mph
1995 Ford Contour SE automatic 0-60: 7.8 sec 0-100: 21.6 sec 1/4 mile: 16.1 @ 87.3mph top speed: 134mph
these figures are pretty acurate, but there's always a margin for error... in the real world, these times can/will be better or worse, depending on who's driving and the condition of the car.
-zero
-1998 Ford Contour SVT E0 BLACK and beautiful, bone stock -1993 Mitsubishi Eclipse GSX 2.0 dohc I4t 5m/awd, not bone stock -1993 Pontiac Grand Am GT 2.3 dohc I4 Quad 4 HO 5m/fwd, beater
Posts: 462 |
couple more:
1997 Ford Probe GTS automatic 0-60: 8.2 sec 0-100: 22.8 sec 1/4 mile: 16.3 @ 86.0mph top speed: 132mph
1999 Mercury Cougar V6 manual 0-60: 7.9 sec 0-100: 20.8 sec 1/4 mile: 15.8 @ 87.8mph top speed: 137mph
-zero
Posts: 9,178 |
hey zerosvt how about a Zetec with the ATX?
Posts: 9,178 |
a 99 zetec with atx that is
Posts: 462 |
shouldn't it be pretty close to the 98 GL atx? if you know the weight difference (if any) between those years, I can get more specific stats. curb weights would help the most, so I can adjust the other models too. CARTEST has the weight for the 98GL ATX as 2950lbs. I don't know how accurate this is. Sometimes you have to fine-tune some stats to get more accurate. also wheel/tire sizes would help. any other requests? I like comparing cars...
-zero
Posts: 9,178 |
I think the Se in 95 had the duratec.....Mine has 15" stock 6 point rims. If that makes any difference.
Posts: 462 |
ok, I dropped the Zetec into a 1995 SE atx and dropped about 60lbs since it's a 4 cylinder. I think the 98GL atx stats would be more accurate. I don't know how accurate this is but it came out with:
0-60: 9.7 0-100: 30.7 1/4 mile: 17.5 @ 79.1mph top speed: 121mph lateral accel: .83g
it rates the Zetec at 125hp/130ft-lb, is that right? I always thought it was higher...
-zero
Posts: 9,178 |
Posts: 202 |
