Posts: 4,585 |
I'm not sure how the Contour's T/C system works. It can be done by applying the brake and using the ABS sensors, limiting power (cutting injectors), or both. But, Jason F. is right, if you have the ABS modual, you have all the hardware you need. Cutting injoectors is purely software.
Personally, I think TC is a waste on a manual trans FWD car.
Posts: 1,202 |
Originally posted by Chow: Cris how did you know, the TC light???? Actually, it lights up Traction Control right in the gauges just to the left of the steering wheel, where all of the warning light indicators are located.
Posts: 1,202 |
Originally posted by -HWCM-: I thought they ,the tc cars,had different tbs? You have a SVT tb? If I recall there was something about the SVT that made it near impossible to put TC on a SVT?  That only applies to pre 98 vehicles which had a electromechanical TC system. The 98 and newer vehicles have a completely electronic system that does not affect the TB. That is why newer vehicles can have the SVT TB installed, even if equipped with TC.
Posts: 1,444 |
front windscreen "de-icer" Crap!!!! Why is Ford sitting on its ass? Why can't we get these options.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 156 |
Originally posted by cawong11: Here's the scoop. TC was not on the option list for any SVT Contour, but I currently own one that does. By fluke or by mistake, I own one very unique SVT. The wiring was already there for the switch, but it was already known that it had TC, prior. The traction control light lighting up in the gauge cluster, when the front tires were loosing traction in wet conditions, and during initial drive clean testing, were dead give aways.
The switch was added at a later date. Ok, besides the light, how else can you tell if you have it or not?
2000 SVT Contour Silver
IN Process "3.0L w/Turbo"
Born In Kansas on 12/16/99 Engine Died on 6/18/2002 18,223 still at Ford as of 7/5/02
#986 of 2150
Posts: 156 |
Ok, I popped out the blank button cover, and I was so happy it was there. I didn't believe you at first "Sorry" ....
But, I order the switch from Ford, but I was wondering something. I looked in my Owners manual, and they showed that the Rear Defogger button on the right, and the TC Button on the left. My Rear Defogger button is on the left. What part # is the correct switch? Thanks
#986 of 2150
Posts: 1,202 |
Originally posted by godzilia: Ok, I popped out the blank button cover, and I was so happy it was there. I didn't believe you at first "Sorry" ....
But, I order the switch from Ford, but I was wondering something. I looked in my Owners manual, and they showed that the Rear Defogger button on the right, and the TC Button on the left. My Rear Defogger button is on the left. What part # is the correct switch? Thanks Yup, that the way it is. Just reverse the plugs. It doesn't matter which side the switches are. That's the way mine is, TC on the left, defrost on the right
Posts: 148 |
So when you remove the blank button cover next to the defog button what is suppose to behind there? What does it look like?
98 SVT Black w/ Midnight Blue Stock Rims Sparco Pedals Removed Resonator TH Fix Superwhite Bulbs B&M Shifter K&N Filter KVR Cross-drilled rotors (front) KVR Pads (front/back) Aeroquip Steel brake lines (front) #4248 of 6535 built 15.574 @ 88.35mph 15.814 @ 86.62mph
Posts: 171 |
Originally posted by MrPc: So when you remove the blank button cover next to the defog button what is suppose to behind there? What does it look like? The buttons are attached together in one fixture, pulling the fixture out reveals two wiring harnesses, one to the defroster and one to the blank button. You'd have to get the ford fixture that handles both defroster and TC buttons, or you could rig it, which can't be hard I'd just hate to screw up and fry it, though I'd love to see if it works first before getting the 20 dollar piece that might not work. Chris
T.Red 1999 Contour SVT God-Awful exhaust tips  Dunlop SP5000 (225/50-16) email: the.jack@verizon.net
Posts: 1,202 |
Originally posted by MrPc: So when you remove the blank button cover next to the defog button what is suppose to behind there? What does it look like? An extra plug, a blue one IIRC. The extra plug/wiring was for the TC.
