#341094 05/31/01 03:03 AM
scratch Offline OP
Cardoc, anyone? Need someone to fill me in on how to do this mod. Please smile
A.J. (Scratch)
2000 SVT
Black/Prairie Tan
(Guinness Edition)
147/2150
KKM Tru-Rev
Motorsport 9mm Wire Set
PIAA Super Whites
Amber Fog Lights
Razo Carbon Fiber Pedals
Richbrook Shifter/Em. brk
AOL Im:AFrint7065
phrint@hotmail.com
Q
Q
It's a 5 volt resistor placed in the power line of the air temperature sensor that is located just before the throttle body in the intake. It adjusts the fuel flow accordingly to give the correct amount of fuel to the engine when it is running at high rpms. This is accomplished by "fooling" the computer by making it believe the air temperature is 20 degrees cooler than it actually is. You see Ford, being as conservative about the environment as they always are have starved our engines of the fuel that they need when they need it most, therefore cutting into our fun. This mod causes a huge gain in power over 4000 rpm and costs only $.20. Thanks to Dom for the idea and the part to do it by the way. :p
98.5 SVT ~ diamond white metallic custom DuPount paint ~ shaved antenna, trunk key hole, and ding strips ~ roof mounted antenna ~ 20% tint ~ clear corners (front) ~ Audi A4 sidemarkers ~ 17" Mille Mille Evo 5 wheels with Yokahama Parada Spec-2 tires ~ Koni adj. struts ~ Eibach springs ~ SMA rear strut tower brace (front no longer fits ~ Powerstop cross-drilled rotors ~ Mintex A/F pads ~ ploy bushings including motor mount insert ~ 3L conversion ~ full custom intake ~ custom Cardoc exhaust ~ gutted precats ~ 24lb injectors ~ 3L upper and lower intakes ~ Rear dome light mod ~ glovebox light mod ~ lighted moon-roof switch mod ~ fog light mod ~ Autometer shift light ~ FCO indiglow guages ~ body color interior bits ~ some custom sound
Administrator www.fordcontour.org
Hehe... actually it's a 5.6Kohm resistor placed in the 5volt signal return line to the computer... But yes.. It does do some amazing things on the top end.
Dom cool
Dom cool
There are advantages and dissadvantages about this mod. Correct?
So where is the how to?
Or is this a secret Cardoc mod.. wink
Also, I need clarification.. You are telling me that Ford runs our engines on the LEAN side at high RPMs? That is scary.
After this mod, is power lost anywhere else in the RPM band?
Later,
Patrick
mailto:paw@ite.com
Still plays with cars
1999 SVT #2003/2760
Born on 04/22/99
F
F
I finally got off my lazy butt and did this. I didnt notice any difference in the lower rpm's, And, since I am pretty much grandpa, I dont take it too high in the rpm's either....but the few times I did, it pulled pretty good.
Thanks Dom
BTW, working on putting the new exhaust pipes Got all my Hardware, and just need to find the time to put it in.
Seeya
Mike
Seeya
FUseface
"Superhero Extrordinaire"
"I am Nigh-Invulnerable!"
97 LX Sport
AIM:MiguelAD8
Ok... I'll be perfectly frank when I say that it doesn't have the same effect on the non-SVT engines as it does on mine. This was a study and it has yielded some interesting results.. More based on the fact of the way the SVT fuel mixture is controlled and also the mean enrichment on full acceleration..
I have a ton of ideas right now and I'm in the process of procuring parts for a little minor intake overhaul shortly.. Including injectors.. So stay tuned.. You never know what you'll read about next.. And BTW.. I did get the ok to bring the Viper to the meet.. But do I really want to is the question..lol Hmm 1997 with 9,000 miles on it.. HEHEHEHEHEHE!!!!!
Dom cool
F
F
Ok... I'll be perfectly frank cool
OK uh...Frank laugh
I just figured it was because I need it for work, and I dont beat the crap outta it...maybe I will test it tomorrow laugh
I can hear the wheels spinning over here in Buffalo...I would imagine we have some cool surprises at the next meet to check out...
WE'll have to get you an evil scientists hat and glasses.
Pretty soon there is going to be a new web site.... www.cardoctorstinkersite.com
Hey, ya never know.
CYA
Mike
Seeya
FUseface
97 LX Sport
AIM:MiguelAD8
Hey Mike,
Could you find me that evil scientist hat and those glasses?? They may come in handy real soon...lol
Dom cool
2
2
hay dom, u have a how too on that yet?
Its a bird, its a plane...wait!..W.T.F.W.T..?
#1800 of 2150
Moderated by  WorldTour_dup1
