i am looking into torque converters for my ATX (much overlooked mod) and i need to know what size or how many bolts it requires. Chris this one might be for you cause there are very few us us ATX modders. Or do we have a AOD or AODE Atx
'99 Contour SE Sport, 50k, V-6, ATX, T-Red, With Many many mods.
'99 GMC Sonoma SLS, 16k, 4-cyl, Summit white, not as many mods.
Founder of Ghost Tech Racing inc.
AIM-FordMondeoS
"Time does not exist in this dimention; but in a time and a place we know not of..." -A. P. Stidwell
Administrator
Administrator
Level Ten is the only place I know of that makes aftermarket TC's for the CD4E.
The stock TC stall is around 2250 RPM. As you might guess, that's a lot lower than the Duratec, or even Zetec makes good power. Depending on what you want this stall converter to work best with, you have a range to mess with. For drag racing, you might want to have it as high as 4000, but you need to keep "streetability" in mind. Too high, and you're revving the crap out of it from a stop light.
For driving and occasional trips down the quarter, I would go for a 3500-ish stall. If I was going to drag it more, I would go up to 4000. Anything higher and you'll think your tranny is broken.
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
Also how about lockup or non-lock up TC? Which would be best?
99 SE
Mods in planning.
Audio:
Pioneer DEH-3000 CD player
Mephis coaxles replacing all factory Speakers
2 Orion XTR Pros 15"
2 Orion Xtreme 900s 900w to each 15
1 Orion Xtreme 500.4 powering the Coaxles
Administrator
Administrator
They all lock up. It just depends on when they lock up. With a SuperChip, the PCM makes the TC lock fairly soon and stays locked for a while. Even during decelleration, you can feel that the TC is locked.
I can't think of a TC that doesn't lock, unless the tranny is low one fluid, or it's broken wink
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
Thats half true. Some lock some dont. Tho i dont see the benifit in not having it lock. Oh, BTW Chris could you paint my lamps Mandarin Copper Metallic Clearcoat? The paint code is B6. What do ya think?
AIM-FordMondeoS
Administrator
Administrator
Originally posted by DconNavi:
...Oh, BTW Chris could you paint my lamps Mandarin Copper Metallic Clearcoat? The paint code is B6. What do ya think?
That would have to go to a paint shop. Unless you have some in a can.
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
