-HWCM- Offline OP
Ok I got a Belkin router and hooked it up like im supposed to.Everything went fine,both connections work and can get on the net.But my connection speed,or time it takes to load a page is super slow.I meen Dial up slow some times.
I dont have the second computer hooked up permanently yet,I just plugged my lap top up to the second line to see if it was working.
Why would this slow me down so much,I was told,that there would be no noticeable difference.
Here is another problem.When I tried to put everything back the way it was,my main pc wont connect(this is with the router removed,and the line plugged straight into my pc from the modem).
I tried reseting the modem and restarting the computer doesnt work either.So now Im stuck with a really slow Cable connection.
HELP ME!!!!!! mad
Howard
1998 Silverfrost SVT #1612
June mods:
17" ADR RS Limited Limix Wheels
with 215/45/17 Yokohama AVS Sports
E
E
If I have the router connected, like I do now, it takes a complete restart for MSIE to see the internet again after the router is disconencted.
Does your router have any lights on it telling you what speed the computers are attached at? My Linksys has some, and I know that this computer has the slowest connection in the house. frown Its still cable speed though. smile
Other then that, I can't help much more. I am not good with routers. frown
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
Did you fix your virus problem? That would slow your connection down. Scan your machine for viruses just to be sure.
MAKE SURE YOU ARE USING THE LATEST VIRUS UPDATE LIST!
Try that first. Then let us know.
Two questions:
One: Do you use PPPoE to connect with your cable modem, or is it a static IP? If it's PPPoE you have to change what's called your MTU setting to 1492. Standard MTU setting is 1500 (bytes), but with PPPoE, it has what's called a "header" that's 8 bytes. This can cause slower speeds, and you'll definitely see this on large downloads.
Two: Did you do any patches yet? If not, go to www.speedguide.com and download their speed patches if you're running Windows.
Any questions/problems, let me know or PM me!
Cable also can slow to less than 56k during peak hours. Have you tried using it in the middle of the night!
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
Kai Offline
Even more important than the MTU that Rynn mention, is your Tcp Recieve Window. Windows comes otimized for dialup, but with broadband, this really limits you. Go to www.dslreports.com and download Dr. Tcp. It's the easiest way to change the values (otherwise it's into the registry). Also, they have good speed tests there to show before/after speeds. As far as the value you should use for the RcvWin, it depends on the speed of the line. I use 32767 for my DSL connection, and odds are that would work fine for you too. Most importantly though, run the tweak test a DSLreports ( http://www.dslreports.com/tweaks ), and it'll suggest things you can do to help the connection.
Hope this helps!
Kendall
'97 GL Zetec ATX
" Nippy "
W00t for Kai smile l33t like me smile
LOL j/k
Kai's suggestions are great too, I used the patches on www.speedguide.net tho. If you want to edit your MTU, then Dr. TCP is great as well smile
-HWCM- Offline OP
I never had a virus,just someone trying to get me to open an email with one.
Howard
June mods:
-HWCM- Offline OP
-Andy
Up untill I connected this router I was getting outstanding speeds at any time of the day.I have a patch running already,and I do usually get on after midnight.
Howard
June mods:
-HWCM- Offline OP
Your Tweakable Settings:
Receive Window (RWIN): 65535
Window Scaling: off
Path MTU Discovery: ON
RFC1323 Window Scaling: OFF
RFC1323 Time Stamping: OFF
Selective Acks: ON
MSS requested: 1460
TTL:
(less any hops behind firewall)
127
TTL remaining: 110
Notes and recommendations:
Input line speed for RWIN recommendation
Looking good
Example 146000 byte download
Actual data bytes sent: 146000
Actual data packets: 100
Max packet sent (MTU): 1500
Max packet recd (MTU): 1500
Retransmitted data packets: 0
sacks you sent: 0
pushed data pkts: 5
data transmit time: 0.441 secs
our max idletime: 58.5 ms
transfer rate: 201153 bytes/sec
transfer rate: 1609 kbits/sec
This is not a speed test!
transfer efficiency: 100%
Good data stream (no/few rexmits)
ICMP (ping) check
Minimum ping: 38 ms
Maximum ping: 42 ms
Ping stability:
41 39 39 40 42 40 40 38 39 39
Looking good
Here is what I got,tell what it meens.It seems to be working better today for some reason.
Howard
June mods:
