Posts: 4,476 |
lots of you have lately chimed in stating the underhood temps of our cars (especially the V6 models) have some pretty extreme temps under the hood - let's get some "cool" ideas [pun intended] to get some of the "heat" out of the enginebay...
the metal from the intake is like a huge radiator under the hood....
i believe that if someone can create a composite intake we would probably lower the temps by at least 30 degrees...
it's essentially "free" horsepower and helps with engine longevity....
Todd Christ SVT Contour Registry MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator '98 E0 SVT Contour #1037 of 6535
Posts: 4,042 |
I've always wanted to run without the hood.  John
Posts: 4,476 |
not only inexpensive - but looks cheap too!  haha
Posts: 1,071 |
Moving the battery to the trunk makes a big difference as well. Also gives you more room to play around will different intske setups.
Speed kills, but it beats going slow! Simon Langley Black 98 SVT EO (#2119 of 6535) 269.3 FWHP, 195.4 TQ 14.123 @ 97.36 All go, and no show! Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust. CDW-27 1/4 Mile Registry
Posts: 168 |
Does anyone make any decent looking hood scoops, or even better cowl induction?
Speed limit on PIT ROW 15mph chevy drivers TRY YOUR BEST!!
Posts: 355 |
someone make a carb. fiber or ABS intake, something like that that doesnt conduct heat so well!
Posts: 2,906 |
Someone make me a carbon body replacement with hood scoops, vents, and fender vents
Spattmobili®
Posts: 1,701 |
How about cooling off the oil filter that sits right next to the exhaust manifold. I look at that every time I do an oil change and think of trying wierd things with hoses. (No, not that wierd...)
Posts: 4,476 |
does anyone know if that Mirko ram-air hood (still in pre-production) will provide cooling too? would be nice!!!!
Posts: 1,041 |
Those who are running the cold air intakes might benefit from coating it or wrapping it up. I first thought of using those Thermo Tec wraps to keep the heat down. But it looks kinda ugly and at this point I would like it to shine under the hood. Anyways I than looked into Jet Hot Coatings. Ceramic coatings that work on headers and exhausts, etc. have to work on a CAI. So after talking with them I shipped it to them. It's still shiny as I like it and runs estimated 30% cooler. The throttle is more responsive and I notice my engine running cooler. After a hard run I can actually put my hand on the CAI vs. not being able to put a finger on it before. Just a suggestion.Sorry for the crappy pic. BTW the CAI was fabricated by INJEN TECHNOLOGY, and I use a WEAPON R foam filter.
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
