Originally posted by -HWCM-:
Originally posted by Pete D:
[b]Internet connection sharing would not work in your case. Although I have used it, basically if you had 2 NIC's or a modem to the net and your computer had to be the gateway for your 'network' (hope that didn't confuse you too much).
Get a router, under $100 can get you a belkin or netgear or linksys or d-link..... Most of them have integrated firewalls which are really good, if you don't do a lot of gaming.
You could get a hub too, for like $40-50 but there is a bit of a performance hit, especially if you have more than say 2-3 computers on it
HTH,
Pete
Thanks! I just got the Belkin!Found one hidden way back in ebay,6 days away,and use buy it now HERE! .Got it for $45! $80 elsewhere.Now gotta get some cable.Cat 5 or cat 6?
[/b]Pick up some Cat5. Unless you can find 5e or 6 for close to the same price. You won't be pulling enough data across to notice any difference. Hell, you could even run cat 3 if you so desired.
