Posts: 5,805 |
Coming to 'a store near you' in 4 weeks... Save your engine from a costly waterpump failure,improve warmup time,reduce power loss from your waterpump,prevent afterboil on 'hot shut downs',set your engine coolant operating temp to YOUR desired setting....Unique package for all stoc V6 Contours/SVT & Cougars.Custom packages for t/c -s/c, modded intakes etc can be made to order....dont change out that stoc waterpump yet !!!!
Posts: 105 |
98.5 SVT 93RX7 86GT 377ci
Posts: 3,248 |
Do tell. An electric water pump?
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 5,805 |
Yes,with electronic controller!!
Posts: 407 |
Isn't the water pump driven off the camshaft? If so, will there be any power increase? A good reliablilty mod though ... so many good things on the horizon.
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
Posts: 5,805 |
Most waterpumps,mechanical need around 6KW to drive the impeller.but dont need max flow rates as the cooling improves via the rad when it has airflow,same reason we have electric fans.On the highway they are seldom on,same applies to the waterpump.
Administrator
Administrator
Posts: 5,037 |
Hurry, Terry, before mine blows!! 64,000 miles and counting
Posts: 3,562 |
Any preliminary costs Terry? Looking to do a preventative maintenance change out on mine sometime before winter and would love a performance option...
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 5,805 |
Not as yet,will be finalised when package is finished,however the pump & controller will carry a 2 year warranty.I'm going with one of,if not the, best developed and produced pumps in the world.The company has had a 'zero defect' rating for many years and is an OEM.
Posts: 460 |
Terry's turning into the one stop shop for TRUE Duratec performance heads...keep addressing the REAL issues we have with the engines and you will do well...
nik
1999 Mercury Cougar V6 KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
