Posts: 1,687 |
just picked up a '00 Mustang GT 5 speed for the girlfriend last week. been searching the net for a while about the best mods to do and wanted to get some good input from the experts here. I want to do the Vortech S/C before the end of the summer but I'd like to do the exhaust, gears and all that good stuff first. I'd also like suggestions on a solid suspension set-up as well. any help would really be appreciated.
Posts: 3,598 |
Suspension: chassis stiffening first, get some full-length subframe connectors from maximummotorsports. Then try upgrading the struts/shocks/springs. The Bullitt kit is a decent upgrade for the price (like $360) and isn't harsh at all (600/250#). They use revalved Tokiko's. Upgrading from that would be something like I've got, Bilstein dampers with 850/300# springs. Caster/camber plates let you dial in tons of caster for a much better "on-center" feel on the highway. I'm running Maxmotorsports plates.
From there you can do stuff like rear LCA's (Griggs and MM both have good, non-binding setups) and panhard bars. This is good enough for 95% of the people out there. Taking it further (either a parallel 4-link or torque-arm setup) is usually over-kill for street driving.
If you're planning on sticking N/A, 3.73's are a good gear for the 4.6 GT's. An aluminum driveshaft is a must. Also, upgrade the shifter to a Pro5.0 or Tri-ax before you kill a shift-fork in the T45.
If you're gonna put a blower on it, then hold off on intake mods. If not, then do some basic stuff like a Densecharger (PVC cold-air kit) and a Pro-M. Shorty headers on a 4.6 GT are about worthless (2-3hp). X-pipes (Bassani, Magnaflow) are a proven mod. Depending on your rear suspension plans, hold off on the catback.
I gotta do some stuff, so I'll get back to this later if you want more info.
HTH
\'94 Cobra #4963/5009, black on black, not quite stock Formerly owned a black '00 SVT, #1972 Join the SVTOA! RIP - Ray "Old Fart Emeritus" McNairy
Administrator
Administrator
Posts: 4,527 |
Hella, 1) Read carefully over what Bassen just posted. 2) Send me a PM or something, and we can discuss, I do know a thing or two about the newer stangs
It's all about balance.
bcphillips@peoplepc.com
Posts: 563 |
1.steeda timing adjuster 2.drop in K&N 3. bullet intake if going with a vortech? 4.underdrive pullies 5.4.10's
I don't think the 4.10s are an over kill, on the way to the world ford challenge in st.lous we were tachin about 2,200 @75 I believe. Steve I thought the newer ones went with a 3550 or the 3650 tremec? Or was there a change over in 2000 to 2001. we went with a pro 5.0 after he had bent the forks on two transmissions. I would put that at the top of the list. Hey rara come up with anything on my combo?
Dustyn Red 1998 SVT E1 95 Mustang GT Yeah there both slow New ram clutch for sale Sho shop pullies and belt for sale 30 bucks
Posts: 3,598 |
4.10's are fine, too.
The 3560 was a mid-year change over for the 01MY, at least for the GT. All Bullitts and Cobras had them.
Posts: 396 |
I don't know a lot about mustangs... but I will second the recommendation for the Steeda Triax shifter... the thing is incredible - got it on the T5 in my XR.
Administrator
Administrator
Posts: 4,527 |
Sorry Dustyn, I completely forgot, I'll go back and mull your setup over, and see what we can come up w/.
