Posts: 149 |
I have a '53 M38-A1 Jeep that I am building up. I have gone from a one barrel to a Webber two barrel. After I start the engine it sputters and dies after a few seconds. If I give it some gas, it hesitates then sputters and dies. It will not start unless I pump the throttle first. I have had the mixture screw out and it all the way. It just seems like it's running out of gas.
I just need a few ideas before I start taking things apart to check things out.
Mark
00 svt tour- K/N filter, SHO SHOP Y pipe, 2 1/2" back to rear Y, improved tunes.
91 sho- Hi flow Y pipe, 2 1/2" exhaust, edlebrock rpm series 2 1/2" muffs, modified intake, K/N filter, modified manifold, 190 lph fuel pump, magnacor wires, ford double platinum plugs, underdrive pullies, custom LPM, 8 pound aluminum flywheel, hi revs race duel diaphragm kevlar clutch, solid torque limiters, poly bushings evrywhere, heavy duty subframe bushings, heavy duty engine and trans mounts, subframe connectors, front and rear strut tower braces, eibach springs, tokico struts, camber ajustment plates, light weight swaybar end links, cross drilled rotors, carbon fiber pads, 225/55/16 SP 5000's, redline water weter, redline trans fluid, mobil 1 synthetic oil, police grill and the need for speed!!! It's a chronic disease.
Posts: 2,847 |
Weber Specialists The above link is to Pierce Manifolds, they specialize in Weber carbureators. Maybe give them a call. Maybe you need a bigger fuel pump, just guessing there. Hope that helps a bit!
Posts: 515 |
Check for stuck float or needle valve. Check fuel pump. Errr...is there fuel in the tank?
"My Name is Richard. I am a Contouraholic." 1999 SE Sport Duratec ATX Spruce Green; Drop--In K&N Filter; VentShades; Fog Lamp Fix Mod & PIAA510s with Bumper Braces & Stock Type aiming screw mod; PIAA 9006 Super White Headlamps AIWA CDC-MP3 HU; WeatherTech Mats Viper 600ESP w/Remote entry
Posts: 149 |
Originally posted by Contouraholic: Check for stuck float or needle valve. Check fuel pump. Errr...is there fuel in the tank? LOL! If anyone were to leave fuel out of the tank, it would be me :rolleyes: I checked the float and guess what, It was so out of ajustment that it would not even open. The carb was taken out of a MG about 10 years ago. It ran then so, I assumed it would be fine when I rebuilt it. That's what I get for assuming The engine runs great now, considering all the tuning that still needs to be done. I like easy fixes Thanks
Mark
Posts: 3,066 |
don't assume, you make an ass out of u and me =)
STD's are like Pokemon... Gotta catch em' all!
