Posts: 1,184 |
I need to remove the vocal on a song, I have Sound blast acid and sound blast forge
how do I do it
1996 Mercury Mystique stock (so far)
The leading cause of Atheism in the world are Christians, who accept Jesus with their mouth but walk out the door and deny him by their actions. (*DC Talks greatest hits. track 15)
Posts: 956 |
I know Steinberg Nuendo does that... It is a very Professional program... Difficult to get though..
I think Cool Edit Pro could do that too.. I am not sure...
** CT - USA **
* 96 Contour Gl 2.0 5 Speed Manual / Clarion CD Change 8" Subwoofer & Sony Amp (LOUD !!) The Cleanest !!!
* 92 Mazda Protege 5 Speed Manual / 1.8
* 94 Yamaha Virago 535 (better than Viagra !!)
Posts: 79 |
I always thought it was impossible to remove the vocal that is over top of the music. I don't know how you would remove the vocal without taking out the audio underneath it, but definately something I'd like to know as well (if it's possible).
Posts: 244 |
If you have a Soundblaster Live! or Audigy, look in the EAX and FX settings... it can remove the vocals on the fly ( and you can record using 'What you Hear' ).
Cool Edit has a filter to remove vocals as well. I've never used that filter, but if it's as well as the rest of the program, it should work for you.
--JamesT
>--------------< --Chemguru
99 CSVT Frost /Mid. Blue
00 Suzuki SV650 Red, Naked
Posts: 446 |
Originally posted by aMac: I always thought it was impossible to remove the vocal that is over top of the music. I don't know how you would remove the vocal without taking out the audio underneath it, but definately something I'd like to know as well (if it's possible). Everything is usually recorded in tracks(unless there is a single mic in the middle of the room while the whole band plays...which sounds like crap). So, the drums record on at least one track...usually more cause there is a bass drum mic, and snare mic, a tom mic and cymbals. Then the bass is on a track and the guitar is on a track and the vocals are on a track. Then you can put special effects on different tracks and such. This is when the whole mixing thing comes into play to make everything blend...PITA. So, if you have the right program you can mute a track. At least this is what I think they are talkin about. I know this is the way it works while recording as I have done a lot of this. HTH. ><>David<><
"this world has nothing to offer, come back soon." luti-kriss throwing myself an act of my own violation '98 Black SVT- 3949/6535 8k miles ticked away, Eibach springs, Koni Struts, SHOShop CAI, Ford 9mm racing wires, deleted res., lead foot...more to come. http://community.webshots.com/user/svtminiflea
Posts: 244 |
Originally posted by SVTMini-Flea: {snip}Everything is usually recorded in tracks(unless there is a single mic in the middle of the room while the whole band plays...which sounds like crap). So, the drums record on at least one track...usually more cause there is a bass drum mic, and snare mic, a tom mic and cymbals. Then the bass is on a track and the guitar is on a track and the vocals are on a track. Then you can put special effects on different tracks and such. This is when the whole mixing thing comes into play to make everything blend...PITA. So, if you have the right program you can mute a track. At least this is what I think they are talkin about. I know this is the way it works while recording as I have done a lot of this. HTH. ><>David<>< It's not really the removal ofa the vocal track, as that would require the complete mix ( every track, plus the mixing schema, etc ). The filters basically scan the song for a pitch line that dynamically changes in between a set range. Translation... it looks for the 'virtual track' in or about the pitch range of a human voice and eliminates it. I'm sure it's WAY more complicated than that... but... I think that's the idea. --JamesT
