Administrator
Administrator
Posts: 4,527 |
It's all about balance.
bcphillips@peoplepc.com
Posts: 1,201 |
The APEXi was the mod I was planning next too. I found a local dyno to help me tune it. 295 is cheaper than I could find it. Keep me up to date.
If it's true that we are here to help others, then what exactly are the others here for?
Posts: 1,682 |
everything i have read suggests that the pcm does not use the O2 sensors at WOT... But when i ran my dyno run with a bad downstream HOS and a CEL it ran really poor. Now that i have a good O2 sensor I think i will give it another pull (as soon as i clear up the cam noise, sticky throttle, and bad tranny/motor mounts). If i don't see gains of about 10-15 hp, and 15-20lb/ft of tq, i am gonna be really pissed at SHM.
Administrator
Administrator
Posts: 4,527 |
at WOT, the O2 is not ignored, but it is put into background processing, ie it doesn't have nearly as much say over what happens.
Posts: 1,682 |
Originally posted by Rara: at WOT, the O2 is not ignored, but it is put into background processing, ie it doesn't have nearly as much say over what happens. does an MIL hurt performance?
Administrator
Administrator
Posts: 4,527 |
the little light will never hurt performance, however whatever is causing the little light to come on has varying effects on performance, sometimes very significantly poor effects
