Posts: 3,421 |
Well i was wondering if there was anyway to turn it off for when im playing games. See i play Unreal tournament and with my old DSL(BIGNET) people use to be able to join my room. Well i switched DSL servers(Ameritech) and now people cant join, Is there any way i can turn this off for just game use and it to stay on when im online. Anyway around the firewall so people can join my room. Thanks for any info
Posts: 1,496 |
You should be able to enable IP forwarding through your firewall. You can enable certain TCP/UDP ports while disabling others. Find what port you connect through, then enable it through your firewall.
Regards,
JaTo Overland Park, KS JaTo@kc.rr.com
99 Contour SVT #143/2760 Modded to Taste
00 Corvette Coupe Modded to Haste
Posts: 2,729 |
Would it be any differance for a cable modem? I have that and play Halo for Xbox online occasionaly.
Posts: 314 |
Shouldn't be any different for a Cablemodem.
2000 Silver ZX3 1999 SVT Contour RIP 6/9/02
Posts: 1,210 |
SBC/Ameritech.... :rolleyes: x1000
Posts: 3,598 |
Originally posted by JaTo: You should be able to enable IP forwarding through your firewall. You can enable certain TCP/UDP ports while disabling others. Find what port you connect through, then enable it through your firewall.
Regards, OMG, James posted! ![laugh laugh](/ubbthreads/images/graemlins/default/laugh.gif)
\'94 Cobra #4963/5009, black on black, not quite stock Formerly owned a black '00 SVT, #1972 Join the SVTOA! RIP - Ray "Old Fart Emeritus" McNairy
Posts: 494 |
Originally posted by I-Dom-In-8: Well i was wondering if there was anyway to turn it off for when im playing games. See i play Unreal tournament and with my old DSL(BIGNET) people use to be able to join my room. Well i switched DSL servers(Ameritech) and now people cant join, Is there any way i can turn this off for just game use and it to stay on when im online. Anyway around the firewall so people can join my room. Thanks for any info I have the same problem with Diablo1 over the internet. I have to turn off the firewall all together. Stephen
96 Contour, GL, Zetec, ATX. 03/18/1996 Build Date. Drop in K&N NGK Laser Platinum Premium Spark plugs Niehoff Premium Ignition wires Wheel Well Air Intake Resonator removed. *Just the beginning*
Posts: 770 |
You should seek an answer/advice from ppl who play that game and use firewalls...is there a UT forum you can visit? Also try searching on Google.com
The medium you are using to get the connection doesn't matter - cable, DSL, etc. (ppoe can be a biatch though)
Andrew 99 SVT
Posts: 494 |
The reason why I have the trouble is because my firewall automaticaly blocks "unknown" packets!
In order for me to be able to play online with others my connection has to be able to allow those packets.
It is easier to just turn it off than to try and filter what I need! :rolleyes:
Stephen
Posts: 1,496 |
Originally posted by Steve Bassen: Originally posted by JaTo: [b]You should be able to enable IP forwarding through your firewall. You can enable certain TCP/UDP ports while disabling others. Find what port you connect through, then enable it through your firewall.
[/b]Been a while, hasn't it? I'm plowing the boards again, due that I've got most of my long-haul work travel over with for the year. So, yes, it's back to putting up with me and my sordid opinions. ![laugh laugh](/ubbthreads/images/graemlins/default/laugh.gif)
