Page 1 of 3 1 2 3
Rynn Offline OP
I happened to catch Top Gun today on a movie channel and a question started going through my head. I'm not very knowledgable in avionics and flight physics, but, why is it that you can't recover from a flat spin? If you want, you can give a detailed answer, I don't mind smile I'm just curious because I'm a huge fan of flight simulators and combat flight sim games (many of them with very realistic conditions in the programming of the game) and every time I've made myself go into a flat spin, it's impossible to get out of it; why doesn't the plane just increase the throttle and go forward? Wouldn't the force of the jet engines stop it from spinning? Also, what exactly causes a flat spin?
Thanks in advance, I hope someone knows what I'm talking about! smile
In a flat spin (like that pictured in the movie), there is a total loss of lift at the wings. Since the aircraft is spinning about a vertical axis through its center of mass, increasing engine thrust doesn't work because the thrust is continously vectored in a shifting direction as the aircraft spins, and thus the aircraft gains no velocity from engine thrust that would be beneficial for generating lift. Again, no lift, no flight...
I'm no avionics expert, nor am I well experienced with flight sims nor do I hold any type of pilots license, but I believe that if you could get the nose of the aircraft pointed toward the ground,a nd given enough altitude, you could recover from a flat spin. Unfortunately, the same conditions in a flat spin that prohibit lift likely also eliminate any chance that the control surfaces- elevators, alerons, flaps, rudder, will have much effect on vectoring the aircraft....
95 Contour SE ATX V6
"Cracked" Secondaries
DMD Installed
SVT Brakes
Rynn Offline OP
Sandman, thank you! That was the kind of answer I was looking for smile Just enough detail to sate my curiousity cool
Anyone else have more to add to this? smile I'd really really love to hear it!!!
Many aircraft are quite capable of recovering from flat spins. The F-14, however, is not one of them. It all comes down to the basic flight control system and areodynamics.
I had the chance to watch spin testing in the NASA spin tunnel at NASA Langley back in college (Aero/Mech double major eek ). They used scale models with working flight controls in a verticle wind tunnel. Very cool to watch, and the only test model thay couldn't recover during the demo....the F-14A. laugh
Very few of life's problems can not be solved with the reasonable application of more horsepower!
2001 SVT Mustang Cobra
My Ride
Former Owner of:
'00 Contour SVT #1931/2150
I wonder if the ability to vary the geometry of individual wings might help in that problem, changing the center of mass just enough to move some air over a control surface.
TB
Tony Boner
H
H
yeah what he said- my boss was a flight test engineer in the AF for about 11 years- - you CAN recover from a flat spin- but the F-14 is a plane that is virtually impossible to recover.
'98 SVT #2253
Currently DEAD!
Cobra Paradise
Awwww Top Gun.... One of my favorite movies of all time. Damn I'd kill to have another one made!! With the technology today..... TOP GUN II would be the shizzle!!!!!!!!!
"Nothing like coming off the on ramp in 3rd gear. Just let her eat and enjoy the awesome sound she makes. Ahhh, the joys of an SVT."
'98 SVT
#3754
What is your favorite sim? Mine is Falcon 4.0 and European Air War. I've heard that Falcon 4 has been flown by real F-16 pilots and said it was identical. All I know is that it takes a lot of skill to fly it right.
Chad Purser
'98 Silver SVT
Mostly Stock
Rynn Offline OP
Falcon 4.0 and MS Combat Flight Sim are my favorites, and also F-16 Multirole Fighter smile
Jane's ATF was always cool.
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
Page 1 of 3 1 2 3
