#32694 08/02/01 03:46 AM
Does anyone know how to get rid of this. Its really annoying when I am working on my car and want to have the radio on
Sony CDX-M750 Cd Player,
Clarion Ungo RS151,
Liteglow Neons,
9006's Low Beams,
885 Xenon Fogs,
Fog Light Mod
#32695 08/02/01 03:50 AM
Same question here. In my 2000, the chime (loud) comes from an all-in-one unit in the fuse panel under the dash, when you remove it, you also lose the interior lighting (thanks Ford). :rolleyes: Are the pre 98's similar?
Stefan - Livonia, MI
ceg@rairigh.cc
'00 SE Sport
Deep Navy Blue
Fog light mod
A4 Sidemarkers
Window tint
Bullitt Fuel Door
Perma-Cap Fuel Filler Cap
98 clock
#32696 08/02/01 04:14 AM
Funny you should ask...This is the first mod I performed on my SVT when I bought it. That was a year ago let me see if I can remember how to do this!
Under the dash, there is a box attached to the fuse box. It sort of unplugs, which I did.
Then I took a pair if wire cutters and cut a hole in the side of the box near where the speaker is. Be carefull where your cutting.
Then I took a knife and cute the two leads on the bottom of the little speaker. By the way the speaker is a circular black plastic thingy (It doesn't look like a real speaker, almost like a speaker on a modem only biger)
Anyways once I cut the speaker free I removed it completely and took some electrical tape and tried my best to cover the two now cut leads. Then once you are doen plug it back in and TADAH no sound.
This is just what I did becuase I couldn't figure out what else to do! There may be a less painful way. If you would like more explaination let me know, I might be able to elaborate more.
Sound ghetto but it worked for me!
Hope it helps.
Justin
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
#32697 08/02/01 07:39 AM
One of my first mods too. Did it same time I did the fog light mod... Since I was down there...
2000 SVT #674 - Check it out!
