Posts: 1,831 |
The next revolution in Computers is supposed to be instant on machines. Have read a few articles on the subject and people feel we are still a few years out. Said most likely 2005 for machines to become equppied like this.
#1 complaint of users is the boot time lag so people know there is money to be made.
Posts: 2,848 |
Instant on machines...well, you can actually buy a device that works like a hard drive, except with RAM memory instead. Problem is, it's $$$. I remember seeing on tv a type of flash memory that would work for instant on computers. Was still being researched. Some kid at MIT actually used potato chip bags to make the stuff! That was like last year. All other options are simply too expensive.
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Posts: 335 |
The company I was going to do hardware design for was there. I saw an 8GB solid state drive (basically flash). What I would give to have one of those!
Current Cars:
2000 CSVT #398 / 2150 - TRed
85 CRX si with a suspension harder then Ron Jeremy on Viagra.
Posts: 1,196 |
Many older Macintosh machines would boot in 7 seconds or less, because there was nothing necessary to pre-load before you use the operating system. My own Mac PowerBook 3400 can boot that quick if I specify "extentions off".
I believe if you got a Mac Classic and had the OS boot from the ROM (as suggested here), it would boot in 4 seconds or less. Pretty fast for a 25 MHz computer with (if you're lucky) 4 MB RAM!
Matthew 98.5 Contour SE V6 It has spent 1.5 years under the wrong identity ;-)
Posts: 730 |
Don't worry, IBM is working on it. Current RAM really isn't too good, hence the development of Magnetic RAM, or MRAM. Here\'s a good article at How Stuff Works. It also said that Flash memory, though it can be used, was deemed too unreliable to be used for PCs.
Kendall '97 GL Zetec ATX " Nippy "
Posts: 3,636 |
My sun desktop is instant on. We are using SunRay workstations. I put my smartcard in and my desktop re-appears. The really cool thing about this is if I want to share something with my co-workers. I walk over to his cube, ask if we can swap smart cards for a moment, and instantly, my desktop is on his workstation. Of course, we have a pretty beefy Ultra-Enterprise 5500 serving up the desktops http://www.sun.com/products/sunray/ TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Posts: 4,899 |
There is a similar option in W2K called Hibernate.
Posts: 2,848 |
yeah and hibernate often takes as long to reload as a properly configured PC booting normally.
Posts: 1,795 |
You mean you turn off your computer?
Every time I come online I wonder if the forums will be up
Posts: 220 |
Originally posted by Pete D: You mean you turn off your computer? This brings up a question I've asked quite a few people lately and have gotten conflicting answers... I run Windows Millenium Edition at home (had that installed after my Win98 had a catastrophic failure) and now I don't shut it down, I just run it on standby and shut the monitor off, 'cause the last time I shut it down the mofo never came back on.  I've been told this isn't a problem, and some peeps have said I'm crazy for doing it. I only use it for internet surfing and not much else (occasional CD burning). What's the consensus around here?? I'm just asking because I'm an idiot when it comes to computers.
2000 SVT Contour Black/Tan, #193/2150
1994 Cavalier V6 almost ready to die
