Posts: 4,042 |
Originally posted by IceHeart400: As I recall, the Commodore's a full sized car, not between the 3 and 5 series BMW, but bigger than even the 7... I seriuosly doubt that. I think it's just a tiny bit bigger than the 3-series.
Posts: 4,528 |
Originally posted by IceHeart400: As I recall, the Commodore's a full sized car, not between the 3 and 5 series BMW, but bigger than even the 7... Ah no. I don't think anything is bigger then a 740il. John is right about a 5 series size. A little smaller.
Posts: 2,961 |
Well, first, it's going about the size of the 5-series (189" long), so it's a bit bigger than I'd care for (6" shorter is ideal). However, the basic issue is that a sports sedan does not use a big cube V8. I want something with more finesse and sophistication, and gets better gas mileage. This thing will probably get about 18mpg overall, like Camaros get.
Also, FWIW, the Australian version is making only 300 hp.
Pricing should be decent, at least, in the $26-$28K range, using yesterday's exchange rates.
It's a muscle sedan, like the Marauder is going to be and the old Impala SS. I want something that isn't a throwback to the 60's, but uses a modern DOHC 24valve V6 or small 32valve V8.
You can pillage an enemy once, but a customer is an endless resource.
James Oerichbauer - PFPC Global Fund Services
Ross: 1998 E0 SVT Contour, Toreador Red, Konis, Superchip, KKM w/heat shield, SHO-shop y-pipe and rear strut brace, no res, ScotchCal, Moda Sport 16x7.5 wheels with 205/55ZR16 Dayton Dayton tires... more
Posts: 345 |
Autoweek said that if they bring it in they not only have to change over to LHD, they have to re-do all the interior plastic bits because of North American temperature variations.
"Holden's GTS coupe may be first of several of GM Australian vehicles on way to U.S.
Holden's GTS coupe may not be the only Aussie runner that General Motors vice chairman Bob Lutz is eyeing for U.S. import. Word is that in addition to the 402-hp coupe, GM's product guru also likes the Maloo sport/ute (think Chevy El Camino) for these shores. Lutz reportedly wants GM to bring up to 20,000 Holden Monaro coupes per year to the United States, if the car can be economically adapted to meet federal crash regulations. Another obstacle: We're told a U.S. version would require reworking all the plastics for cold weather durability—not typically a problem Down Under where plastics must stand up to heat, but not cold. Redoing the plastics for U.S. vehicles could take up to two years, sources say. "
AL
Red '98 SVT E0 3098/6535 KKM, Elizabethan EGR Plate, TH fix OMP front brace Hightower rear brace DMD B&M with reverse lockout disabled and centering spring removed Mobil 1 oil and trans fluid A6 Side Markers, Optima orange, Horn recontent Painted Sail Panels VooDoo Knob and pedals, RogerR deadpedal Blau Houston & CD changer Cup holders that work Donnelly mirror BAT Sill Plates and a Bullitt fuel door
Posts: 449 |
I've had a chance to drive one while over seas. It Rocks!!! They have them in LHD in Europe, and they call them Lumina's. It's a big mid sized car, alot like the size of the current Impala, just a hell of a lot nicer! As long as they don't "Americanize" it too much. Holden Commodore SS
Posts: 1,195 |
Originally posted by goldsmi: Autoweek said that if they bring it in they not only have to change over to LHD, they have to re-do all the interior plastic bits because of North American temperature variations.
AL the holden Ute SS  me like that alot available with V8 and a Manual tranny me like A very LOT
97 Zetec MTX Sport Esslinger UDP; Nology HotWires and BERU Silverstones; Sylvania Silverstars (high beam in low beam) Dual Fiamm air horns Mk1 Mondeo Clear corners(and yes I made them fit....) Boston FS80's in the front
Micah's PRE98 SVT front bumper, W/ Mirko splitter(yet to be painted)
Rally drivers do it sideways......
Email: Roknut@linkline.com AIM: AphexTwinGrin
Posts: 85 |
Um 350hp V8? thats gona be loads of torque steer - well if they did it to the caddys guess there no reason askin.
Posts: 1,090 |
Originally posted by svtcarboy: Well, first, it's going about the size of the 5-series (189" long), so it's a bit bigger than I'd care for (6" shorter is ideal). However, the basic issue is that a sports sedan does not use a big cube V8. I want something with more finesse and sophistication, and gets better gas mileage. This thing will probably get about 18mpg overall, like Camaros get.
It's a muscle sedan, like the Marauder is going to be and the old Impala SS. I want something that isn't a throwback to the 60's, but uses a modern DOHC 24valve V6 or small 32valve V8. Okay, but you're saying it's a "muscle car" because of the pushrod engine, but it's hard to argue the rest of the car, because the Z28 was a live axle car. That's the only thing in common with the Z28 and Vette, the engine. I don't like the fact that GM still uses pushrod technology, but don't tell me that it doesn't work, because the Z06 has 405 hp this year. And 350 CI? that's 5.7L, the MB E55 uses a 5.4L, and the BMW M5 uses a 5.0. I know your arguement is those cars are multiple cams, multiple valves, but the displacement is there as well. It's the Australian engine that makes 300 hp, but the "rumor" from Motor Trend is 350 hp here. Maybe some tweaking to be done by GM here? If you like your cars smaller with multiple cams, the Cobra or M3 is for you. For me, I need four doors with a newborn!
Posts: 1,090 |
Originally posted by noknowbalance: Um 350hp V8? thats gona be loads of torque steer - well if they did it to the caddys guess there no reason askin. Uh, the Commodore/Caddy Catera are both RWD.
Posts: 1,687 |
Lord know's anything's better than the god awful piece of donkey sh*t they try to pass off as an Impala but bringing over the commodore is fantastic. If they do bring over Holden's GTS 300 coupe, that will most likely be my next daily driver if the price is right. stazi know's whats up  ..
