Posts: 1,687 |
Okay I've just about had it with my computer, I bought 1 1/2 years ago to do alot of web design and to get on the internet. So far, I can barely ever get anything done because it locks up so much. The damn thing came with Windows ME which sucked beyond belief so I switched to 98. That sucked just as bad so I switched again to 2000 the week before last. Now it sucks worse than ever before, it locks up after about 5 minutes of browsing and I don't even dare going into photoshop or flash. Is there something I can do to make this thing run better or should I take it to a shop? Here's the specs Compaq Presario 5000 Series 900 Mhz AMD Athlon 192MB memory (upgraded from 64 originally) 40 Gig HD 32MB graphics card (upgraded from pathetic 8mb card) DVD/CDRW Drives I'm thinking I'm going to do the smart thing and build a new computer considering the wealth of information I learned from kraftys post today. But I was hoping to get this one in better running condition so I could sell it on Ebay or use it as a workstation at my company. I know we got some smart guys on here so any help would really, really be appreciated. im dyin over here lol ![laugh laugh](/ubbthreads/images/graemlins/default/laugh.gif) :rolleyes:
Master P
Master P
Posts: 5,455 |
Try taking out your newer memory chip and seeing how it does. It could be a little flaky and causing some problems.
Posts: 1,773 |
most likely a hardware issue. my experience w/ 2000 is suprisingly positive /* I use professional @ work and server on my newer machine @ home */ it does not necessarily have to be memory, but I'm guessing the reason Perry brought this up is that normally OE parts are tested to work together, while whatever you are adding may bring in new issues. another problem is that ME and 2000 are completely different animals. what was supposed to work w/ ME does not have to do so w/ 2000. in other words lots of things may be going wrong. You might want to try and get the newest drivers for whatever hardware you are using, but be aware that messing up w/ them may be dangerous. if 2000 driver is n/a use NT one. and one more thing, if you decide to upgrade from your current motherboard to something better it's not gonna go as you might expect. stupid windoze saves information about your hardware in the registry, so once you change your motherboard it refuses to boot up. don't ask... ![laugh laugh](/ubbthreads/images/graemlins/default/laugh.gif)
--alex | 96 GL(sort of) V6 ATX | 98 SE V6 MTX Sport
Posts: 193 |
when you switched OS's, did you reformat the machine? ive had problems with that, not doing a clean install, under 2000 in particular. i recommend reformatting computers every half a year or a year, that usually helps me out. check for heat issues too, those can be a b**ch.
96 Contour SE, MTX 2 Pioneer 12"s in a bandpass box 2 5x7 Pioneer Plates 2 Stock Speakers 600 watts of blistering radioshack power
Posts: 3,636 |
I know how you can eliminate ALL pesky windows lockups www.sun.com TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Posts: 462 |
If swapping memory don't work, remove the heatsink (but be carefull) and check the processor chip to make sure it isn't cracked or crushed. Go to http://web14.compaq.com/falco/sp_list.asp and enter information for your computer. It will list all available diags and drivers and BIOS upgrades.
98.5 Contour SVT Kenwood KDC-MP8017 MP3/CD Player Meaning of life is SOLO II
Posts: 621 |
CPU lockups are one of the most difficult problems to trouble shoot.
You might have a software or hardware conflict (usually the culprit. loaded any new software lately?), your memory chip might suck, your processor-mobo-or hard drive even could be overheating (do you have a case fan in addition to CPU fan?), your disk drive might be fragged (try defragging), are you good on disk space? (you should be with a 40g), last but not least...when was the last time you restarted your machine? I can usually go for 3-4 days without restarting if I'm not hammering the machine. After that the system resources start dropping too low and performance starts to suck.
I'm running Win98, 450 k6-2, 256ram, 8g hard drive so I have to be on top of all those above things to keep the box running right. Plus I have all kind of peripherals attached so that saps resources too.
Posts: 3,636 |
Heat can be an issue with lockups as well.
Could be something as simple as the CPU fan is toast.
TB
Posts: 1,559 |
O.K. my recommendation is to check all the fans in the case. I know that particular series is either Slot A or maybe a Socket A. Compaq didn't include a Fan on the CPU for the Slot A processors and they are prone to overheating. If this is the case with yours (the CPU will be a long rectangular Box standing up right in the Case, much like a Pentium 2-3 Slot 1) I would reccommend buying a new CPU or just replacing the system.
Remove the power cord form the back of the system!!
You open the case by undoing the the thumb screws on the(If staring at the front of the case) left side and sliding it off. Next lay the system down so that you are staring into it. Then there are two large screws on the top back at either side of the back case that you remove to swing the PSU and the top half down to access the CPU and expansion slots. look to see if the CPU is a socket a or slot A if Slot A don't touch the damned thing it'll burn your finger! If socket A (It will look like a small square heatsink with a fan on it.) plug the power back into the PSU and push the power button. See what fans spin up. They all should so if one doesn't then it needs to be replaced. Hold the power button in until the system shuts off and cycle the system a few more times. Sometimes movement will free a fan to spin for a small amount of time but it will stop working shortly. Then report bacl to us with your findings.
I offer no warrenty on my advice. If you kill yourslef it's not my fault.
Posts: 1,355 |
It's all OS issues. It sounds like you didn't do clean installs when you went back from ME to 98 (not good) then from 98 to 2000. Your PC sounds fine hardware wise. Unless these lock up's accured AFTER you upgraded your memory. Miss-matched memory WILL cause lock ups. Did you check your manual for memory compatabilities?
I would remove the memory you aded for a while and run your system, does it lock up?
If it's not the memory, first thing I would do is Format and fdisk that HDD, Install a clean copy of 2000 and you will be fine.
I would NOT JUMP in and start messing with your chip, fans etc just yet. Start at the begging and work up the ladder. There are MANY things that could be causing this, the CPU is one at the end of the list (only because it either works or it doens't. There is no way, if it was cracked or "crushed", which I have no idea HOW that would or could happen, that it would even boot, never mind working in Windows, it just wouldn't work at all).
You have to try and establish WHEN the lock ups started. WHAT CHANGED? That will help you find out what is wrong.
Simon W. Las Vegas. 96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!) 1999 SVT Engine SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT "it's only nuts and bolts" - Terry Haines "Drive it like you stole it" - Me!
