No plans yet! Maybe Superbowl party. Make sure if you replace the cables or have had the replaced make sure you or whoever did them didn't just use the clamp on ends. they allow corrosion to wick through the wires which is bad. It is always worth going ahead and buying factory type cables. Give me a call at 447-0792 if you have any other questions or want to get together this weekend.
Crazy Contour Guy 1995 Contour SE (ATX) Alpine 7863 MTX Thunder4250D Amp. 2 pairs of PolkAudio EX 572A's MTX 2-way X-over network 3 10' BlueThunders 4 ga. Streetwires power wire kit Esoteric zero-noise RCA's Streetwires power block Xenon Super Plasma White Headlight and fog light bulbs Blue mood interior lights KKM airfilter 9 mm Motorsport Racing Plug wires
