Posts: 650 |
Cindy 1998 Black SVT #1129 DOB: 5/20/97 1980 Mazda RX-7 1988 Mazda RX-7 Convertible (for sale!) 1986 Mazda RX-7
Posts: 1,762 |
I think the deal with the clutch is like follows:
Take the black cars flywheel (Slightly larger/lighter) and resurface it and then take one of Chris' spare clutchs that he has laying around and bolt that into place. Should save Joe around $200 and have a little better grip than his stock (1982) setup had. But I am sure once it wears out he will stick a Racing Beat Stree/Strip clutch in because thats all he has talked about for a month now!!!
Exiled from the KYCEG community forever
Posts: 294 |
Don't forget Black car's starter!!!
James '89 Plymouth Colt GT Turbo (Rapid Transit Turbocan) '80 Mazda RX-7 GS (da AutoX Bish!) '85 RX-7 GSL (da Partz Bish!) '98 Ford Contour SVT (Wifey's Car:) )
Posts: 1,762 |
Originally posted by James of the hill people: Don't forget Black car's starter!!! Yes that will prolly be swapped over as well! Hopefully the engine will be ok after sitting for a while! I don't see any reason it shouldn't be, but still.....
Posts: 505 |
Joe, think the 89 flywheel will bolt up to you 12A? Would save us from having to source one from the black car. It's also 1lb lighter!!!
Chris
Chris 2001.5 Dodge Ram/Cummins 2500 1986 SCCA/ITS RX7 roadracer
2001 KY Region and Tri-Region STS Champion
Posts: 1,192 |
joe will not be on untill thur. b/c he broke the internet
My firebird broke again
Posts: 682 |
I don't see why the 89 FW wouldn't bolt up....  Only one way to find out
Joe Coleman Louisville, KY 2000 Ford Contour SE Sport 5spd. Med. Steel Blue Metallic #12 STS - Retired
'82 Mazda Rx-7 #12 CSP - AutoX Beater '85 Mazda Rx-7
Posts: 682 |
Originally posted by rrxp689: Joe, think the 89 flywheel will bolt up to you 12A? Would save us from having to source one from the black car. It's also 1lb lighter!!!
Chris Does it have a counter weight with it?? If so that would make things much easier...but if not, I'm sure we can use Blackie's.
Posts: 505 |
Yeah I got the counter weight. Didn't really wanna use that though. Have you asked anyone on the RX7 forums if it'll even work? Do that before we throw a bunch of parts around.
Chris
Posts: 505 |
This is from the Mazdatrix site. Looks like we can do it. We just gotta make sure the counter weight is right. Which one is right?
"NOTE: Excluding the TURBO, all the different flywheels and clutches, from 74 through 92, are basically divided by 215mm clutch (74-82), and 225mm (83-92), then by rear counterweight needed for the engine. We mix and match these all the time. This means if you want to put the larger diameter clutch assembly on a pre-83 application, just let us know - it is no problem. You just need to remember what diameter you have when you next purchase clutch parts."
Chris
