#32128 07/13/01 12:09 AM
D Davis Offline OP
Decided to remove the rubber thing that runs between the airbox and fenderwell (pardon me if I f*ck up some of the terms). When I looked at the airbox I noticed what seems like an air-chanelling device (black, cylindrical plastic piece) that sits under the filter. I toyed with the idea of taking it out, but wondered if it might hinder the cars ability to suck air properly since it won't deposit the air so close to the opposite end of the filter. I hope somebody knows what I'm getting it.
Also, if I should take it out, how in the Hell do you do it? I didn't want to snap it, but it seems like the only way to remove it.
125.2 FWHP - 126.5 FWTQ
SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!)
Black '98.5 SE Zetec MTX
Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
#32129 07/13/01 12:13 AM
Let me look at before you go snapping anything.
If it's true that we are here to help others, then what exactly are the others here for?
#32130 07/13/01 12:19 AM
D Davis Offline OP
gnarly laugh
(When was the last time you heard that word?)
#32131 07/13/01 01:16 AM
N
N
I remover the tube thing (looks like a vacume attachment). There is no difference at all.
I use gnarly all the time. It is a totally gnarly word!
#32132 07/13/01 02:30 AM
Before I installed my KKM, I had removed that internal baffle as well...caused no problems that I'm aware of...
Andrew Morris
\'99 SE Zetec ATX
All of life's big problems include the words "indictment" or "inoperable." Everything else is small stuff.
#32133 07/13/01 02:25 PM
that was the first thing I did when I saw it. I think it's to quiet the intake. No real big performance gains or anything just useless flow restriction.
**Spelling should not count**
2000 SE Zetec ATX
Medium Steel Blue (Now with large custom dent on the rear door)
Cool Blue Lows, Silver Star Highs (great lights)
"If what I said was wrong, it wasn't. I just forgot to add the rest of my post."
#32134 07/13/01 02:40 PM
There's been other posts regarding "opening up" the airbox (check old forums) & yes the cone part is an attempt at silencing the intake noise.
I sliced the cone off, left the rubber coupler connected (as a possible source for cooler air) & opened up the sides of the airbox for more airflow.
While some people on this board advocate a K&N drop in filter, I feel that a paper element eliminates the need for re-oiling periodically with no contamination of the MAF.
The only penalty for opening up the air cleaner is a more frequent replacement of the filter element. Difference in sound occurs only under acceleration. Normal driving is quiet (sleeper mode).
Seat-of-pants dyno indicates better response all around (Zetecs need all the help they can get!).
Cheers! smile
Is the smoke alarm in your house also known as the "dinner bell"?
'99 Zetec VCT Daily Driver
Mild Air Filter Mod
#32135 07/13/01 02:42 PM
you're right luckie,thats exactly what it does. FYI it's called the intake resonator.
#32136 07/13/01 03:30 PM
What the hell were they thinking when they did all this crap. Intake resonator in the air box, worse intake resonator on the TB.
2000 SE Zetec ATX
#32137 07/13/01 04:27 PM
I assume you haven't found the huge "snorkel" resonator that's inside the fender? It's on the other side of the rubber connector and curves all the way over the fender behind the fender liner. It's close to 2 feet long!
Andrew Morris
\'99 SE Zetec ATX
