Posts: 1,192 |
the only typo is 95-97 and 98-99
1993 - 1995 1995 - 1998 1999 2000 - 2001 Type L32 L36 3800 Series II L36 3800 Series II L36 3800 Series II Configuration OHV 60° V6 OHV 90° V6 OHV 90° V6 OHV 90° V6 Displacement 3.4L (204 ci) 3.8L (231 ci) 3.8L (231 ci) 3.8L (231 ci) Engine Block Cast Iron Cast Iron Cast Iron Cast Iron Bore 3.62 in 3.8 in (96.52 mm) 3.8 in (96.52 mm) 3.8 in (96.52 mm) Stroke 3.31 in 3.4 in (86.36 mm) 3.4 in (86.36 mm) 3.4 in (86.36 mm) Compression Ratio 9.0:1 9.4:1 9.4:1 9.4:1 Firing Order 1-2-3-4-5-6 1-6-5-4-3-2 1-6-5-4-3-2 1-6-5-4-3-2 Fuel 87 octane 87 octane 87 octane 87 octane Fuel System SFI SFI SFI SFI Fuel Pressure ? psi (ignition ON) 3-10 psi loss at idle 48-55 psi (ignition ON) 3-10 psi loss at idle 48-55 psi (ignition ON) 3-10 psi loss at idle 48-55 psi (ignition ON) 3-10 psi loss at idle Injector Size 17 lbs (AC Delco 217-301) 22 lbs (AC Delco 217-306) 22 lbs (AC Delco 217-306) 22 lbs (AC Delco 217-1436) Cylinder Heads Cast Iron Cast Iron Cast Iron Cast Iron Combustion Chamber ? 64 cc 64 cc 64 cc Intake Valve 1.720 in 1.800 in 1.800 in 1.800 in Exhaust Valve 1.430 in 1.520 in 1.520 in 1.520 in Exhaust Manifold Cast Cast Cast Tubular Intake Manifold @ TB Straight Angled Straight Straight Throttle Body 50 mm 65 mm Hitachi 65 mm Hitachi 65 mm Hitachi MAF ? AC Delco AC Delco AC Delco Thermostat 195° 195° 180° 180° Oil 5W-30 10W-30 10W-30 10W-30 Oil Pressure @ OT 50-65 psi @ 2400 rpm 60 psi @ 1850 rpm 60 psi @ 1850 rpm 60 psi @ 1850 rpm Flywheel Horsepower 160@4500 rpm 200@5200 rpm 200@5200 rpm 200@5200 rpm Flywheel Torque 200@3500 rpm 225@4000 rpm 225@4000 rpm 225@4000 rpm
My firebird broke again
Posts: 1,192 |
it was set up in an excel format, i i cant get it to stay there
Posts: 1,192 |
http://www.firebirdv6.com/ I hate frames, i cant copy the url here
Posts: 234 |
In addition, the supercharger's internal displacement was increased from 62 to 90 cubic inches. Driving the blower 1.8 times faster than crankshaft speed yields a maximum full-throttle boost of 7.5 psi and impressive output: 240 horsepower at 5200 rpm and 280 lb-ft of torque at 3600 rpm.
That's more torque than any other manufacturer offers in a six-cylinder engine, including Porsche's new 911.
i may be missing something but dont 911 turbos make something like 400 lb-ft of torque?
95 Nissan Maxima SE 5speed VQ Power! F33R MY NUTZ! RB26DETT OWNZ JOO!
Posts: 234 |
hey paul any idea on the power to weight ratio of the mirage?
Posts: 1,762 |
Exiled from the KYCEG community forever
Posts: 1,315 |
Last time at the track it weighted 2500 pounds with me in the car, full tank of gas, my 2 1/2 ton jack and box of tools. and the old lil donut tire in the trunk
Paul Brady Ward JUICE BOX SOFA KING! Broad Band JUNKY! F33r Th3 Mirage!
