Posts: 770 |
Has anyone with a K&N in the stock SVT airbox experimented with reflective coatings on the airbox surface? Instead of using a resistor to fool the computer into thinking intake air temperature is colder than it is in reality, a very reflective mylar or adhesive aluminum finish coating on the airbox may reflect some heat and reduce intake air temperature.
T.
Posts: 1,496 |
I've been monkeying around with this idea for a while, and think I'm finally going to spring for some reflective insulation-type material for my KKM heatshield. Logic tells me it has to help somewhat, but as for proof I've none.
Anything for colder air.
JaTo Overland Park, KS JaTo@kc.rr.com
99 Contour SVT #143/2760 Modded to Taste
00 Corvette Coupe Modded to Haste
Posts: 336 |
I have thought about doing this mod...though not quite in the same capacity. Ever been to a store that is really small, and they have mirrors along one wall, and so the place looks twice as big? Well, I was thinking about using a reflective coating to fool the sensors into thinking that the air passageway was twice as large. That way it would put more fuel into the mix, which would burn more fuel, therefore, more power. Follow me?
Let me know how your endeavor turns out. If it goes well I may try it, too, as I will probably buy the reflective mylar in bulk, and may have a lot left over.
The Mark #464 of 6535 A Few GS-ish mods
Posts: 770 |
Well, this is what has me thinking:
"The lower the charge intake temperature, the more power is produced, so the underside of the airbox was given a coating of reflective material to deflect the tremendous amount of engine heat ... this drops intake air temperature by up to 24 degrees, and it's worth as much as 20 bhp because ignition maps push output down to prevent pre-ignition when the air is warmer."
That's from a Bimmer Magazine article about the Nowack N500, an M5-based tuner car. They ended up using the stock airboxes instead of open-elements but with revisions. Comments?
T.
Posts: 268 |
Originally posted by JaTo: I've been monkeying around with this idea for a while, and think I'm finally going to spring for some reflective insulation-type material for my KKM heatshield. Logic tells me it has to help somewhat, but as for proof I've none.
Anything for colder air. Not sure how it would handle the temp of the engine compartment, but what about that stuff they use to make AC/Heat ducts in homes. You know the stuff with 'glass insulation on one side and foil on the other. Could be cut and folded into a box to fit on inside or outside of your shield. They used to make the flexible AC duct wraps with foil backing also. If they still make it, a quick test could be done by wrapping some around the stock air box.
98 evo 0 SVT #2999 of 6535 Silver Frost/Midnight Blue Lotsa bolt-ons
Posts: 1,496 |
I'm thinking along the same lines, but I've seen some stuff that's much thinner that does have some sort of insulation/fiberglass backing as well. I may be nuts, but I'm thinking I saw the stuff at a fireplace/wood stove shop a couple years back.
Either one would probably do the trick.
Posts: 80 |
Do it.. pm me a link for pix, i wana do it! heh..
96 Ford Contour GL, Blue. Custom Color: Pearl/Metal flake, midnight blue..  ATX Zetec Fury Exhaust.. Mods:Removing Catalitic converter, Straight pipe back to the muffler.
Posts: 600 |
Ok, I know what you guys are talking about, but have a different idea: We all know that dark colours attract heat, so why not paint the air box a lighter colour? This will not work as well as the previously mentioned ideas, but it's just a thought. Any opinions- Yes? No?
97' 2.5L Contour SE -T-Red Midas exhaust (grr...), Sony CD player, K&N airfilter, Mobil One Synthetic Oil, removed intake resonator, modified MAF, in-fender CAI, painted grill, Platinum tipped NGK's. I am looking for SVT E0's or E1's, SVT Upper & Lower Intake, SVT Throttle Body, and SVT Exhaust. If you are selling, e-mail me! Ford4eva@hotmail.com
Posts: 508 |
Originally posted by 97TourSE: Ok, I know what you guys are talking about, but have a different idea: We all know that dark colours attract heat, so why not paint the air box a lighter colour? This will not work as well as the previously mentioned ideas, but it's just a thought. Any opinions- Yes? No? I believe that's only the case for light (say sunlight, etc).
Posts: 972 |
*ahem* easy way to cool engine *ahem* hood scoops *clears throat* cold air intake
95 SE Champagne Mettalic True Dual exhaust with X pipe and Redline mufflers KKM Tru Rev intake H&R Springs/KYB struts Apex-i S-AFC 65mm Throttle Body 17" Ace Spades 4 Pt Racing Harness Window Tint all around New Engine @ 117k kilometers G-Tech: 15.6 @ 91.5 MPH
"you officially kick ass" quote from awed CEG'er after i chopped my hood and threw on scoops
RIP 98 SVT silverfrost *nov 4 2001*
