Page 2 of 2 1 2
#309935 03/05/02 10:45 PM
Marv if you do end up getting rid of it let me know. I have some stuff I would like off your car. laugh
-Colter
My Car
#309936 03/06/02 12:22 AM
E
E
The vultures, err, crazy chicken, is already moving in for parts. frown
$2700 is high unless that includes the labor and the engine. To give you an idea, car-part.com is showing plenty of Zetecs from $1500 to $400.
From the sound of it, I would assume you need a new block. The head might still be saveable. It would need to be milled, thats about $100. Gasket set would set you back a few hundred at the most. In my experience, a new shortblock, from say Checker or AutoZone would cost you around $800-$1500. If you only needed the block it would be less. laugh
Going this way also allows you to bump up compression (or lower it for a turbo). You can change cams, get a valve job done on the head for better breathing, etc.
My friend picked up the 2.0L SOHC engine for his neon for $400 with only 40K on the car. He drove the donor car around the lot before he pulled it out too. If you would like, I could put out some feelers around here and look for a new (to you) engine. smile
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
#309937 03/06/02 02:05 AM
H
H
you could always buy my SVT Marv
'98 SVT #2253
Currently DEAD!
Cobra Paradise
#309938 03/06/02 02:07 AM
He ought to buy my car and then I can buy your's Scot. laugh
-Colter
My Car
Page 2 of 2 1 2
Moderated by  Keyser Soze
