#30908 06/17/01 08:30 PM
Ok i only took me 5 hours but it is done. Well to start with it will really help if you have the right tools.
Brecker bar
14mm socket
13mm deep socket
and crow bar
To start with i had to use one jack stand and on jack. not fun. So i start looking at the front part. no problem i think. Then i broke off a bolt head. going wrong way. make sure you go lefty lossy righty tighty. i got the next one off no problem. well besides the really on there part. on the next on i sripted it. Great job. So i bust out the old file and go to work. i filed down each side a bit and then witha extra 13mm socket and a hammer i got it on. then got that one off. next to the back. well you have to have really deep 13mm. some thing i did not have. so geuss what . it stayed on. i pulled the front part down and when to work. after many differnt tools come to find that the crow bar and a hammer works the best. i now have a bunch of bits and pecies of cat guts in it. so i bust out the vacumue. works wonders. after i i got it done i could barly wait to start it.
With it at idle you can't really hear a diffrence. but once you hit it oh man it is there. at high revs no rasp what so ever. just sounds great. i would recomend this to every one. hope you all can do it easyer then me.
Next it figuring out the flamethrower part laugh eek
Michigan CEG BenTonEdge@aol.com
**DEAD** Dec26 01. 96 2.5 Gl dessert violet. mystery mod, gutted cat. no res. craked secondaries. custom air box. And a good old CEL Oh you want to know
#30909 06/18/01 01:32 AM
1
1
What kind of performance did it give you? Been debating whether or not to do it.How much loader is it?
#30910 06/18/01 02:36 AM
thats the way i see myself doing things sometimes.
not quite as planned. oh well, at least it worked.
-jason
#30911 06/18/01 04:48 AM
see i heard taht peopel tah removed the res had a slight problem with rasp. i have none what so ever. i can't really say but there is a more pull. the butt dyno says some thing like 5 hp maybe. just a guess.
#30912 06/19/01 12:08 PM
JNC Offline
Sorry about your luck Ben. I did it this past weekend and it only took my 1 1/2 hours. But your right a shop vac help a lot to clean it out.
'98 Contour SE V6
K&N Drop-in W/O airbox
Costom Rear sway bar brace, ($10 from Lowes)
jcline3@columbus.rr.com
#30913 06/21/01 04:01 AM
I just took mine off laugh
Chow
1998 SVT #2263 of 6535
chowsvt@msn.com
#30914 06/21/01 12:51 PM
And.......what happened? Noise, power?...Details please!
STD's are like Pokemon...
Gotta catch em' all!
#30915 06/21/01 03:47 PM
On my '99 SE the noise didn't go up in Db level, it went down in tone. Power is up in low RPM TQ and high end flow.
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
#30916 06/21/01 06:20 PM
Thank you much Brad, looks like I'll be doing that sometime soon!
