Page 3 of 3 1 2 3
Here's what Mr Noon is up to... Pull them entirely out. Build a 3 liter so you wouldn't need improved low end torque from the secondaries. Problem solved. laugh
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
Originally posted by Rara:
somebody needs to test this on a dyno, it can't be that hard! laugh
if you want to go with me, i will test it in like 1 or 2 weeks...
i am offically a troll... so take my information and advice with a grain of salt.
08/15/2001 - 11/05/2001 : 1999 Ford Contour SVT : 170fwhp - 147.9 fwtq
07/17/2001 - __/__/____ : 2001 Roush Mustang GT Stage 1
11/05/2001 - __/__/____ : 2001 Ford F-150 SVT Lightning
Originally posted by Steve Bassen:
Check out the dyno's on a stock Duratec. The engine runs out of breath right around 3100 when it's just breathing through the primary runners/valves, causing a dip in power until the secondaries open up. Ideally you'd want the secondaries to open up a few hundred rpms sooner than stock.....
i don't have my plots in front of me... but iirc the dip occured at ~3400 rpm just when the secondariers were opening... i took the loss as something to do with air velocity and the maybe something to do with the pcm.
Page 3 of 3 1 2 3
