N
N
I'm sending this out to all Unorthodox clutch owners. Has anyone experienced their new clutches starting to catch when the pedal is close to the floor. Sometimes my clutch starts to catch early and then doesn't engage until the pedal is near the top. It doesn't seem normal, but maybe it's an aftermarket thing. I talked to Unorthodox and they said the release bearing was probably not preloaded. Our cars have a hydraulic self-adjusting clutch so that shouldn't be the problem. Just polling the audience
and any feedback would be greatly appreciated. :rolleyes:
98 Black E0 #946 of 6535
Koni struts & Eibach springs
24mm Aussiebar
Pro Flow 75mm MAFS calibrated to KKM filter
Wilwood Brake Kit with cross-drilled rotors
Clutchmaster's Stage 1 Clutch & Fidanza Flywheel
Custom Dual Exhaust with an Xpipe
MSDS Headers
Custom Cold Air Intake with KKM filter
Dyno'd at 177 hp and 156 ft-lbs
JVT Offline
Actually, yes, it does happen to me.
About 1 out of every 30 times it happens.
Kinda annoying, but what can you do...
John
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
-faster than the above
---wanting a Speed Triple or Superhawk badly
JVT Offline
Also, when the clutch/tranny is cold, pulling away in 1st gear, the clutch 'moans' loudly.
Only moans when pulling away in 1st gear, clutch slightly engaged.
Once the tranny/clutch warms up, no noises whatsoever.
John
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
N
N
Good call, JVT. I forgot to mention the moan. Mine is pretty subtle, but there once in a while during the first shift or two. Thanks! Anyone else? :rolleyes:
24mm Aussiebar
MSDS Headers
F
F
I have had that clutch for about 500 miles now, and just recently, i have noticed a squeeking noise when i go into reverse like in the mornings. Im not sure if its clutch related, but thats wut it does. Also if i have the car in nuetral and its running there is a smalling like ticking/clacking noise heard from the drivetrain area, once u engage the clutch it goes away, they have adjusted it to no avial...and some nights out of the blue, the thing will just start to slip..who knows way, park the car, the next day its fine....it has only did that twice tho.
Any suggestions
SB
Would any of what your experiencing cause premature wear on the clutch??????
Doesnt sound to good.
Simon W. Las Vegas.
96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!)
1999 SVT Engine
SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT
"it's only nuts and bolts" - Terry Haines
"Drive it like you stole it" - Me!
simon how do you like that grizzly clutch? im thinking about getting it
It's great. No problems at all. Still has the stock "feel" to it but the travel of the clutch is less (engages alot better then stock). I'm happy with it totaly! And for $300 its a great replacement from stock which is around the same price.
Simon W. Las Vegas.
1999 SVT Engine
yeah i think i might get it...getting engine replaced...figured a new clutch wouldnt be such a bad idea..where did you get it from?
I got mine from Spmotorsports.com. Although I'm not sure if they are still doing the OEM clutch and just going with the street one. Or its the other way around I cant remember. Good clutches though in my opinion, I've had it now for well over 20k miles. laugh
Simon W. Las Vegas.
1999 SVT Engine
