Posts: 1,391 |
I've emailed Purolator for a distrib. here in Canada. No reply since last week. ( http://www.pureoil.com/home.htm) Have you been to Walmart? Mobil 1 oil filter is a rebranded Puro. I remember buying my Mobil 1 oil there last year?
Joe, 98 GL sport (V6 MTX)
Posts: 179 |
I think that the Mobil 1 is a Champion according the the oil filter study.
I will take a run down there at lunch and see what they have.
// Chris
[This message has been edited by Chris Root (edited February 01, 2001).]
Posts: 179 |
Wasted trip! All they have is Fram krap and AC Delco. I checked the AC Delco cross reference and there is no listing for Contour/Mystique/New Cougar.
// Chris
Posts: 1,391 |
That sucks. I guess I'll be getting a WIX.
Hmmm, that guys website doesn't sound too bad.
"Wix Another quality oil filter similar in design to the Purolator. It has metal end caps on the filter element, a standard nitrile anti-drainback valve, and a seemingly good flow. They are manufactured by the Dana corperation. These appear to have a depth gradient filter element, which uses cotton fibers to progressively trap smaller particles as they get deeper in the filter. This helps maintain good flow as the filter gets plugged. "
Posts: 179 |
Yeah, I will just stick with the Ford (Wix) filter for now. Maybe if Gerald does go to Michigan he can grab some for us.
// Chris
Posts: 581 |
I thought I had seen these somewhere. If I remember correctly, I saw them at either Walmart or at a store called TSC (Tractor Supply Company) They are usually located in small towns. The one I do know of is in Alliston. If you search on the internet in yellowpages.ca you may be able to find others. I am not 100% sure, but I know I've seen them somewhere. Good Luck.
Posts: 1,391 |
Good Idea! I never think of TSC. Is there one beside KW surplus? (between kw surplus and the shoe factory?)
Posts: 179 |
Originally posted by joe: Good Idea! I never think of TSC. Is there one beside KW surplus? (between kw surplus and the shoe factory?)
680 Victoria North.
Posts: 1,391 |
I got this from the source!: --------------------------------------- Thank you for your interest in Purolator filters. The nearest distributor to your location is listed below. If you have any further questions please feel free to contact me..
Monarch Oil 808 Victoria St.N Kitchener, Ont N2G 4B6 PH: 519 743 8241 Fax: 519 743 9802
George Adamczak ArvinMeritor Light Vehicle Aftermarket EMail: George.Adamczak@ArvinMeritor.com Phone : 1 877 254 6882 Ext. 450 Fax : 905 681 7499
Posts: 1,391 |
spoke to the guys there.
$16.39 each. Nothing in stock. That are no distribution center for Purolator filters in Canada so order may take up to two weeks.
