I have a copy of the new catalog from Northstar,which makes aftermaket wheel alignment products, and it lists an adjustable camber/caster plate for the Contique and Cougar. It is designed to fit on top of the front struts and it provides a 2 degree adjustment range. As far as I can tell, there are no kits for rear camber.
I have no idea how much they cost, or where to buy them, though you might want to try your local alignment shop. Part # is 41-4613.
Also in the same catalog is a fancy tool that is suppose to make seperating the strut from the knuckle a lot easier. Part # is 88-9416.
Sorry if this has been posted before, but I thought you guys should know.
