Posts: 18 |
I have a 96 GS 2.0 and the temp has been perfectly fine until now. My temp now is still in "normal" but getting close ro "hot". The major problem is that heat has been coming threw the floor vents on front drivers side. I'm worried about my car being to hot and I don't want to lose performance either. thanx for the help everyone! Also temp has been fluctuating from close to the red and then back down for a couple seconds and then back again. It heats up at idle and on the go.
96 Mercury Mystique 2.0 GS Zetec AT Couple mods. 150hp 148tq. 55K miles
Posts: 785 |
zetecs normally run " hot " when at idle it will go up then when the car is moving it should go back down... you could change the thermostat just in case its faulty and change the temp sensor... my neddle stays between the A and L...
good luck
Later
Red '97 GL Sport MTX IVELISE ================================== "Let every nation know, whether it wishes us well or ill, that we shall pay any price, bear any burden, meet any hardship, support any friend, oppose any foe to assure the survival and success of liberty." John F. Kennedy
Posts: 18 |
but is it normal for a decent amount of heat to come out of the drivers front side lower vents?
Posts: 785 |
do you have any settings on like AC/floor/defrost?
Later
Posts: 3,950 |
Originally posted by 96 Zetec Ogre: but is it normal for a decent amount of heat to come out of the drivers front side lower vents? Depending on how hot is it. I don't mean to go off subject but your sig says 150hp and 148tq. What mods do you have?
Posts: 18 |
only have exhaust and intake now, took the chip and everything else off so i'm running a lot slower at the moment but anyways... no i don't have the AC or heat on and still heat comes out.
Posts: 3,950 |
Then how do you have 150 HP?
Posts: 785 |
Originally posted by LoCo: Originally posted by 96 Zetec Ogre: [b]but is it normal for a decent amount of heat to come out of the drivers front side lower vents? Depending on how hot is it.
I don't mean to go off subject but your sig says 150hp and 148tq. What mods do you have? [/b]w3rd !!!
Posts: 18 |
i dont have 150hp at the moment. i took aftermarket parts out to try to figure out my problem. even with my aftermarket parts uninstalled, its still got the same prob.
Posts: 785 |
ok so to get back into the subject you dont have any setting running when the heat is coming in...loco or some ones might be able to help ya...good luck
Later
