...And some confusing info on stock Zetec cams.
OK, so I got hardcore about doing some research and comparisons on who makes a good overall street/turbo cam. I found good info, but I also found some wierd discrepencies in two major cam manufacturers stock cam specs. OK, first the Turbo cams;
************Duration****D@.50Lift*****GrossLift
Crane Cams**232/228*****210/206********.374/.366
Crower******271/271*****220/220********.374/.374
Esslinger*****258/242*****not listed*****.405/.345
Note: the Crane cams has an additional listed spec of a 110deg lobe separation, and Esslingers cams seem to be geard more toward N/A performance(even though this is their mildest grind listed)
Now, on to the wierdness I found, both Crane and Crower list specs of a stock Zetec cam(I'm assuming from a Focus) but the specs from each manufacturer are completely different confused
Stock Specs;
***********Duration**D@.50Lift****Gross Lift
Crane Cams*229/229***206/205******.350/.342
Crower*****290/286***206/205******.343/.352
Let me close with an invitation for anyone to voice there opinions/technical expertise on which cam would work better with a low C/R high boost turbo application(with possibly a multi-point direct-port NOS wet-system eek ), and lend any insight as to why the stock cam specs seem to vary so widely.
...And I'm spent!!!
Ohsigmachi '96 GL MTX Zetec SS (SuperSleeper)
Suffice it to say my mod list has become so long that it is just ridiculous
