Posts: 2,523 |
Idle Air Control I'm no cheater :p EDIT: I don't even have the DVD w/ me today; it's at home
125.2 FWHP - 126.5 FWTQ SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!) Black '98.5 SE Zetec MTX Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
Posts: 956 |
Idle Air Control... huh.. let me see.... IAC... And your answer is.... WRONG Nice try though... not many people have tried so far... they don't like my quiz...
** CT - USA **
* 96 Contour Gl 2.0 5 Speed Manual / Clarion CD Change 8" Subwoofer & Sony Amp (LOUD !!) The Cleanest !!!
* 92 Mazda Protege 5 Speed Manual / 1.8
* 94 Yamaha Virago 535 (better than Viagra !!)
Posts: 2,523 |
Gimme a hint - did I get the abbreviation right?
Posts: 956 |
Originally posted by D Davis: Gimme a hint - did I get the abbreviation right? You are on the wrong path... Just let your subconscious guide you....
** CT - USA **
Posts: 816 |
That's the speed sensor. You should now be able to go 145mph. Seriously though, does it measure battery voltage?
"Wow, that sank fast." "Yeah, like a rock." 96 Contour GL ATX 9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned Sony CD player: 50wattsx4;remote; Speakers=50 watt Pioneer 6x8s Ross Evans
Posts: 956 |
Battery Voltage ????? huh.. let me see.... Battery Voltage... And your answer is....  WRONG That's getting better... Should I post this under general so the Duratech guys could also try it ??
** CT - USA **
Posts: 1,692 |
Originally posted by BBorges: Should I post this under general so the Duratech guys could also try it ?? NO cause they come in here enough and start things with us as it is.... :p
Joe Hartley "yes I know it's a MTX Zetec but it beats having a ATX Duratec" Champagne 96 GL MTX some mods dynoed at 114.2whp and 124.4wtq (pre CTA intake) 16.858 @ 80.76mph (yes it's slow but still faster than D Davis) AIM: ZetecRacing My Site My Profile
Posts: 9,178 |
Oh shit! I know what that is! It's your Flux Capacitor! That's what provides the 1.21 gigawatts that powers your motor!
Posts: 620 |
You sure that thing is a sensor at all? Looks like a simple power connector, or a large fuse or something.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
Posts: 3,950 |
It has something to do with fuel and spark???? The only connection I have seen like that is sitting behind the coil with some wires going up to the fuel rail. I'm figuring has something to do with the injectors.
