Page 2 of 3 1 2 3
#300360 07/09/02 03:10 PM
Are you still using the filter in the stock air box?? If you are then this whole concept will have a positive effect on performance. How much? I don't know. Colder air is better. I don't think you can get more restrictive than the stock res through the fender wall so if you just pull cooler air through there you're good. You'd basically just be getting the air from farther away. If I understand what you guys are talking about.
Just my $.02.
99 SE Zetec ATX
CTA intake
ZX2 FMS wires(that don't fit my oddball coil)
andenthal@mindspring.com
#300361 07/09/02 04:01 PM
Yeah, I removed the large fenderwell intake resonator, but left the inlet tube/boot on to help direct the air into the stock air box. I'm using a K&N panel filter with the stock setup. What I want to do is just get MORE air into the air box via a remote air hose. When I pulled my side turn signal lamp off, I was shocked at how little room there was for air to get by it and into the air box! I want to buy one of those shop vac hoses and clamp it onto the stock inlet boot, then run it down to one of the lower openings in the bumper cover. I also thought that it might me a good idea to fasten one of those vacuum attachments for cleaning the floor to the end of the hose to get more air directed into the hose. At the depot you can get 7' of flexible hose and one of those floor cleaner attachments all for under $20! My only concern after reading all the feedback is water getting into the hose.
1997 Contour GL Sport ATX
Zetec/2.0 liter
K&N High Flow Air Filter
Mobil 1 SuperSyn 5W-30
Mobil 1 Oil Filter (M1-204)
Fram Sure Drain System
Ford Motorsport 9mm Racing Wires
Recontented Fog Lights, Rear Dome Light, Underhood Courtesy Light, Glove Compartment Light
Pirelli HPs
Kenwood in-dash CD player
Infinity 5752cf speakers
World Champion New England Patriots Fan for Life!
Wife's Car:
1998 Contour SE ATX
Duratec/2.5 liter
Mobil 1 Oil Filter (M1-210)
#300362 07/09/02 07:34 PM
Originally posted by J. Salvi:
While purusing the aisles of Home Depot today, I came across something that I think will work as a remote air hose. It's a vacuum hose from a Ridgid Shop Vac. Here's a picture of it:
What do you guys think? Will this work? The inside of the hose was smooth so it shouldn't constrict airflow. The diameter is 2.5" if that matters.
I used that very same piece of hose smile I no longer have the hose directly attached to the open ended cone filter, but I have it dumping the cooler air directly in front of the S&B Powerstack. I need to build an enclosure box to get it sealed off...
'99 Contour SE V6 w/MTX (Black Clearcoat)
'02 Dakota 4.7L V8 2WD X-Cab (Flame Red Clearcoat)
#300363 07/09/02 09:54 PM
I have a piece of metal dryer vent tube lying around; I figure I'll probably stick it in there somewhere to just dump cold air up into the engine compartment and keep the whole under-hood environment a bit cooler. This wouldn't dump air directly at the filter because it would be on the other side of the heat shield -- it would just cool down the pipe and other stuff.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
#300364 07/10/02 05:14 AM
O
O
i did this with the silver dryer hose from the local Home Depot. no noticable gains but i think it helped a little with the heat soak i hear some contour owners complaining about.
just as an after thought it really sucked trying to get the hose to fit threw the fender well. hope this helps
98 Contour GL
CTA intake
Ford Motorsport 9mm wires
Hightower rear strut tower brace
16" sport edition tekno
removed res. Summit turbo muffler($14.75!)
#300365 07/10/02 03:17 PM
Will I notice any gains with the stock setup (minus the large resonator)? I'm leaning toward the shop vac hose as it is more durable and black. Thanks for all the input, I really appreciate it!
Zetec/2.0 liter
Pirelli HPs
Wife's Car:
1998 Contour SE ATX
Duratec/2.5 liter
#300366 07/11/02 06:20 AM
I want to see if there is any gain in this mod. Anybody planning on going to the dyno soon? laugh
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
#300367 07/11/02 03:15 PM
I was also thinking about using this (see picture) at the end of hose to "collect" more air into the air box. What do you think? It's only $6 and I thought it would also make the setup look better. Let me know what you think.
One more thing, what's the best way to mount the hose to the opening in the front bumper? I don't want to put any holes in the cover, so if anyone has a better solution, please let me know. Thanks!
Zetec/2.0 liter
Pirelli HPs
Wife's Car:
1998 Contour SE ATX
Duratec/2.5 liter
#300368 07/11/02 03:50 PM
This is one high powered vaccum cleaner that we're building. Mine currently has about 175-180 ish HP smile
#300369 07/11/02 07:29 PM
Isn't an engine basically a very powerful vacuum? I just want more cold air for not a lot of $$$.
Zetec/2.0 liter
Pirelli HPs
Wife's Car:
1998 Contour SE ATX
Duratec/2.5 liter
Page 2 of 3 1 2 3
