Page 3 of 3 1 2 3
i had a similar problem, however i was installing an autometer tach, there is an easier spot to catch tach signal. there is an ignition box on the firewall behind the air intake that u can catch it at that is where i got mine. i believe it was a white/black wire and it was the 2nd or 3rd pin from the top. i wouldnt know without looking at the car. jus figured i would toss that up. smile
Shaun
95 electric red
ruby interior
2.0 zetec
not stock by any means
lots o goodies
94 plymouth sundance (the beater)
That is the same wire Drumnut is talking about. wink
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
I tried drumnut's "fix" and the wire worked!! thanks man! now my "tuner" friends don't make fun of me anymore!! JK smile
CURRENT RIDE: 95 GL
FORMER RIDE: 99 SVT (www.mysvt.com)
"You only live once, but if you lived my life, once would be enough." -Frank Sinatra
Drumnut Offline OP
Glad to hear it.
Andrew Morris
\'99 SE Zetec ATX
All of life's big problems include the words "indictment" or "inoperable." Everything else is small stuff.
Jontour- Question why did you need to do it since you have a 95? You should have had a signal wire in the loom connector that plugs into the cluster...
Also your using an older PCM was the pinout the same?
Lee Cox
In life begins responsability...
Project Car
Lee, in my 95 GL, there was no number 8 pin in the left hand plug to the harness. I had to add it. I love it, thanks again drumnut!!...
CURRENT RIDE: 95 GL
Page 3 of 3 1 2 3
