Posts: 529 |
Well, Just got done fixing my Mystique cluster w/tach. Earlier today, I posted that my '99 has no tach wire. So I inserted a wire into the drivers side plug on the cluster so that it would contact pin 8 (the tach signal input). I spliced a length of wire to that and ran it through the firewall and spliced that into the brown/blue wire going into the coil pack...worked, but only hat 1/2 what it should (redline was reading 3250rpm's). Apparently this would only work with an aftermarket tach that's adjustable. So, I looked in my Haynes' manual, and found a tach signal wire exiting the PCM.
So... I ran a new wire behind the firewall insulation to the passenger side of the car. Slide out the power steering reservoir. Unscrew the 10mm bolt holding the PCM connector in. Unsnap the dust cover on the connector (a bit tricky, plus be careful not to damage any wires). Look for pin 56 (white/black stripe). There's pin numbers on the end of the connector, starting with 52 on this row. Take one of those quick-snap splicing things (I have no idea what they're really called) and place it around the white/black stripe wire, then insert your tach wire. Crimp closed, snap on the dust cover, and return the PCM plug to it's original position, bolting it down. Replace the PS reservoir. Start the car and you now have a properly functioning stock tach!
Andrew Morris \'99 SE Zetec ATX All of life's big problems include the words "indictment" or "inoperable." Everything else is small stuff.
Posts: 199 |
Awesome....You are A God !!!!!!!! Now to find me a cluster,
BLUE-1999 Contour SE-Zetec-Clear Corner Lights-Nokya 3157 corner bulbs-Kenwood Exelon X815-2-12" Pioneers-4 6x8 3-way pioneers-Cuzo 9006's & 9005's-Glowing Ford Emblem On Decklid-Blue Interior lights-Alarm W/ Remote Starter- Daytime Running Lights-CTA Intake-Winshiel Nozzle Lights-Audi A6 Side Marker Lights-Mesh Grilles (Good Ole Gutter Guard)-Just Added SVT Exaust Thanks For The Idea CEG'ers !!!
Posts: 529 |
I found several on http://www.car-part.com . Got mine from a yard in Texas for $35 plus $7 shipping. BTW - Search for a Speedometer, not Instrument Cluster. For some reason Instrument Cluster doesn't return any results.
Posts: 620 |
Who needs a tach? I have my ear.
An A below middle C is 6600 rpm. Progressing down the scale: G# is 6230 G is 5880 F# is 5550 F is 5240 E is 4945 D# is 4670 D is 4400 C# is 4160 C is 3925 B is 3705 A# is 3500 A is 3300
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
Posts: 1,692 |
Originally posted by Paul Kienitz: Who needs a tach? I have my ear.
An A below middle C is 6600 rpm. Progressing down the scale: G# is 6230 G is 5880 F# is 5550 F is 5240 E is 4945 D# is 4670 D is 4400 C# is 4160 C is 3925 B is 3705 A# is 3500 A is 3300 AND this would never change??? I know mine has changed with every performance mod I have done like the intake and the exaust it changed alot...
Joe Hartley "yes I know it's a MTX Zetec but it beats having a ATX Duratec" Champagne 96 GL MTX some mods dynoed at 114.2whp and 124.4wtq (pre CTA intake) 16.858 @ 80.76mph (yes it's slow but still faster than D Davis) AIM: ZetecRacing My Site My Profile
Posts: 730 |
Glad you got it working, Andrew. I actually took off the computer in hopes of finding the wire back there when I was doing my tach. Don't know why it didn't dawn on me to do what you did.
Kendall '97 GL Zetec ATX " Nippy "
Posts: 3,950 |
Thanks for the info. I will have to try it with the SVT cluster.
Posts: 1,268 |
I found several on http://www.car-part.com. Got mine from a yard in Texas for $35 plus $7 shipping. BTW - Search for a Speedometer, not Instrument Cluster. For some reason Instrument Cluster doesn't return any results. I did a search for headlight assemblies, and a few places want $777 APIECE!!!  Thats gotta be a typo..... Everything else I looked at was priced right though.
-Ken V. psycho_bass@hotmail.com My Car
Posts: 620 |
Originally posted by ZetecRacing: AND this would never change??? I know mine has changed with every performance mod I have done like the intake and the exaust it changed alot... Huh? I don't care what kind of intake or exhaust you have, if the engine goes 4500 RPM, you're going to hear a note of 150 Hz, which is just above a D. Move your piano out into the driveway if you don't believe me.
Posts: 3,950 |
Well tried it and th tach works. Thanks a lot for the find.
