#300172 06/29/02 06:07 PM
Drumnut Offline OP
Ok...General consensus says that same year/engine/transmission clusters should interchange between cars. It also says that only the 2000's had the tach signal wire deleted. Well, looks like Hector isn't the only one with problems.
Well...got a cluster from a '99 Mystique Zetec ATX. Put it in...tachy no worky. Did a search, found that the tach wire should come in on pin 8 of the drivers side connector...I have no wire, and my car is a '99. Did a further search and looked to see if I had the signal wire anywhere under the dash. (The message I read said it was a thin white/black stripe wire coming out of a green connector above the fuse panel) Doesn't appear that I have that either.
Well, I've added the wire to the cluster on pin 8. Is there any way to get a signal to the tach. There has to be a tach signal in there somewhere I can tap into, right?
Andrew Morris
\'99 SE Zetec ATX
All of life's big problems include the words "indictment" or "inoperable." Everything else is small stuff.
Drumnut Offline OP
Ok....found another message from Hector that stated the black/blue wire (it's actually brown/blue on mine) going to the coil pack gives a tach signal. Spliced in to it...tach works, but only at 1/2 normal revs. Any thoughts?
Andrew Morris
\'99 SE Zetec ATX
Kai Offline
If you don't have the white/black out of the green harness, you may find it coming out if the computer. That would be at the firewall, engine-side, passenger-side. That's where the white/black comes from originally.
Kendall
'97 GL Zetec ATX
" Nippy "
Drumnut Offline OP
Thanks, Kai...
Found that information in another search...gonna try it tomorrow when I have more daylight...
Andrew Morris
\'99 SE Zetec ATX
Z
Z
hector and I ahd already found hooking it up off the coil didn't give a correct reading we also tried different resistors and couldn't get a change in the reading off the coil.
Joe Hartley
"yes I know it's a MTX Zetec but it beats having a ATX Duratec"
Champagne 96 GL MTX some mods
dynoed at 114.2whp and 124.4wtq (pre CTA intake)
16.858 @ 80.76mph (yes it's slow but still faster than D Davis)
AIM: ZetecRacing
My Site My Profile
Drumnut Offline OP
Joe...
See my solution here...
http://www.contour.org/cgi-ubb/ultimatebb.cgi?ubb=get_topic;f=33;t=001269
Andrew Morris
\'99 SE Zetec ATX
Z
Z
saw it right after I posted it :p
Joe Hartley
AIM: ZetecRacing
My Site My Profile
i ran mine through the firewall and attached it to a wire coming from the ignition coil.
2000 Contour SE ATX Zetec
Mods- smile
AIM: CZboyovski
SVT exhaust
Z\'s Contour
It's a frequency signal, not a voltage signal, right?
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
Originally posted by Paul Kienitz:
[b]hector and I ahd already found hooking it up off the coil didn't give a correct reading we also tried different resistors and couldn't get a change in the reading off the coil.
It's a frequency signal, not a voltage signal, right?[/b]
You're right. The frequency changes as the RPM's increase and decrease.
-Colter
My Car
