#300009 06/23/02 06:27 PM
W
W
I just got my CTA intake i did a search but didn't get a good answer, is there a heat shield that i can use, and if there is were can i find it. Tanks for any help.
#300010 06/24/02 01:25 PM
You could make one urself...
Someone did a pretty good work.. and posted the whole process with many pictures... And I believe it costed him about $5 !!
Once I get mine CAI i'll be making one too...
Try to run a search on the word "teenage" for topics only.. and u'll find it...
** CT - USA **
* 96 Contour Gl 2.0
5 Speed Manual / Clarion CD Change
8" Subwoofer & Sony Amp (LOUD !!)
The Cleanest !!!
* 92 Mazda Protege
5 Speed Manual / 1.8
* 94 Yamaha Virago 535
(better than Viagra !!)
#300011 06/24/02 01:26 PM
Here it is..
Heat Shield
** CT - USA **
* 96 Contour Gl 2.0
The Cleanest !!!
* 92 Mazda Protege
#300012 06/24/02 04:20 PM
Something went wrong with that url, the end got cut off. Here is the correct one.
There are two addenda that need to be made to that post. One is that the heat shield as pictured there isn't quite complete: it needs a small second piece jammed between the fusebox and the front wall. The second is that, since it's flimsy, after six months of wear and tear it doesn't fit too snugly any more and needs some tape to reduce leakage around all the edges.
But when I install the e-RAM it might get all mangled so I'll wait till then to fix it up... I may need to make a whole new one after the e-RAM is in.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
